Question about Refrigerators
Fridge not cold enough. quit making ice - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 18, 2010
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
My maytag fridge model# mff2558veb4 ice maker is not making ice
Is temperature cold enough in the freezer .if it is cold enough can be water valve or ice maker unit
Mar 08, 2015 | Maytag Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge running constantly and ice maker wont work
sound like it is low on freon ,,,, if so it runs all the time trying to get cold enough to shut down and it wont make ice ,,,, 1st check to make sure the fan inside is blowing, make sure the temp in freezer part is atleast +5 or below if it hasn't cooled right front the start then thats why they got rid of it ,,,,, leaking freon and it cost to much to repair that problem / larry
Nov 29, 2008 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
