Question about RCA H115 MP3 Player
It will not put the disc that came with it on my computer and i have windows vista.
My computer is a Windows Vista and for some reason it is saying that i need to upgrade to Windows XP but i have a Vista so please help me.
I just got one, and the different info that came with it says that it won't work with Windows Vista. I am sure it can, but you have to figure out how.
If I was you I wouldn't worry about using the disc. There are many options out there for getting music off of the interenet and putting it on there that are probably better anyways.
Posted on Jul 07, 2008
I need a repair disk or valid software download for windows vista ultimate. I have my proof of purchase & my key is valid my DVD is missing. I would like to know of any reputable sites that can help?
if you have everything down load it from microsoft site onto a usb stick then burn it onto a disc
or contact microsoft and as for another disc giving all of the details so that they can check their records
Mar 07, 2016 | Microsoft Windows Vista Ultimate Edition
Windows Vista Ultimate x64 disc stopped working. product key still valid. do i need to buy a new one or can i get the disc only somewhere?
When you say it is not working, is it none functional? or is it stating that windows vista is not genuine? because there may be another issue.
May 02, 2012 | Microsoft Windows Vista Ultimate Edition
Hii..I Am Having An Acer Aspire 5050...Well I Installed Windows Vista Ultimate On It But Originally It Was Windows Visa,Therefore,After Installing Windows Vista Ultimate I Tried To Upgrade The...
A solution to that is to install Windows Vista Ultimate on top of your old vista installation. Just insert your Vista DVD and restart your computer. And simply follow the instructions for the installation.
Jan 08, 2011 | Acer Aspire 5610-4648 Notebook
How to reformat the computer?
To reformat the windows vista.There are two options to approach the reformat:
  • Option #1: Boot from the Windows Vista DVD. This is more complicated to do, but it destroys all data and partitions.
  • Option #2: Re-install Vista without leaving the desktop. This preserves the previous installation in a folder called Windows.old. Not all info is wiped, however, and you can't destroy your partitions.
First, restart your system. When the computer starts to boot, look for an option before you get to the Windows screen that reads: “Setup” “CMOS,” or “Bios”. This varies between manufacturers. For example, on the boot screen, it says:
“F2 =Setup”.
The option will flash by quickly so be ready for it and react quickly. You may need to reboot a few times to catch it.
Once in the BIOS, look for a setting that says "Boot" or "Boot Sequence". You might have to dig through the menus with your keyboard’s arrow keys to locate the setting. In the listed as Boot Sequence. And to navigate to Startup, then Boot, and then Boot Priority Setting.
When you find the setting, change your DVD drive so that it occupies the top of the list. The hard drive that contains Windows Vista should be listed as second in the boot list.
And put the Windows Vista installation disc in the designated drive. Now, select the Save Changes and Exit option in the BIOS. The computer will restart and will attempt to read the optical drive you just assigned as the first bootable drive.
The system will use the Windows Vista disc to boot and the reformat and reinstall process will start. But You will need to reinstall any programs that are not bundled with Windows Vista and reinstate your preferences and personal files after reformatting the computer and reinstalling Vista.
Windows Vista Home Premium Edition upgrade Click here.This downloadable version of Windows Vista is an upgrade only. Users can upgrade to Windows Vista Home Premium from Windows XP Home or Windows Media Center edition.
All the Best!
Sep 05, 2010 | Microsoft Windows Vista Home Premium...
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Nov 27, 2009 | NEC Versa VX Notebook
I can't install Bernina Version 4 on my VISTA Operating system PC
As far as I know, Bernina version doesn't work on Windows Vista, you have to upgrade to the next Bernina Designer version which is Vista compatible.
Oct 01, 2009 | Bernina Artista 180
WINDOWS VISTA SCREEN IS BLANK AFTER LOG IN
use windows vista disc or computer recovery discs to reinstall windows vista once done make shur to fill out registration online or if it will let you then do it now after which you should run virus and spyware scan. good luck i hope this helps
Aug 03, 2009 | Computers & Internet
Forgot my windows vista login password
Try to login to safe mode with administrator login and change the password for your user account.
There is no way to bypass user security otherwise in Windows Vista.
Mar 23, 2009 | Acer Aspire 5630 Notebook
Burner does not finalize discs
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TO
  • Windows Vista Ultimate
  • Windows Vista Starter
  • Windows Vista Home Premium
  • Windows Vista Home Basic
  • Windows Vista Enterprise
  • Windows Vista Business 64-bit Edition
  • Windows Vista Ultimate 64-bit Edition
  • Windows Vista Home Premium 64-bit Edition
  • Windows Vista Home Basic 64-bit Edition
  • Windows Vista Enterprise 64-bit Edition
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information loadTOCNode(2, 'resolution'); To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/details.aspx?FamilyId=2E692102-D483-44B0-BBFF-FA87AE019CBE&displaylang=en
Please rate this a fixya
Feb 01, 2009 | Microsoft Windows Media Player
Installing vista
you never said what the problem was ,let me know
also you may have system recovery software installed which would bring your computer back to factory settings
whats the recorded problem
who makes the computer
did you upgrade from 98
did you change ram
these are a few things to think about w/b
May 16, 2008 | Computers & Internet
RCA H115 MP3 Player Logo
62 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
