Question about Panasonic Lumix DMC-FX100 Digital Camera
System Error (Zoom) - Panasonic Lumix DMC-FX100 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 17, 2010
I had this problem on a TZ8 and solved it by taking it apart cleaning it and putting it back together again, taking care to avoid static and touching the lenses. Previously banging it on my hand, shaking it or resetting the setup defaults had only given temporary respites and not always. Sometines I could zoom in a fraction before it would give me the error.
Seeing the cost of repairing it was heading towards the cost of replacing it I thought I'd take a look inside. I couldn't find a free service manual on the internet but did find a two page parts pdf that gave an exploded schematic of the camera. It was a bit daunting to start but not hard at all. It involved:
Taking out the battery!
Unscrewing the back plate (6 screws).
I also took off the front plate but don't think this was necessary
Disconnecting the display (2 leads on clip connectors - flip black part up through 90 degrees to release)
Unscrew shiny metal cover plate (3 screws)
Disconnect the leads over the lens assembly (2 large leads to right side (looking from back), 1 small lead to left)
Unscrew lens assembly (3 silver screws)
Remove camera stand thread from bottom (push in slightly from the bottom to release dot lock then slide towards the left to release the right side)
Remove lens assembly (should now slide out)
Remove back plate (black screws on top including under the cable and one holding white square on the side)
Mark the relative positions of the lens parts with a felt tip pen. (I didn't but would have saved time if I had)
The lens pieces comes apart into six pieces with GENTLE persuasion by twisting and pushing once you've rotated the pieces to the correct position. I used a bit of trial and error here.
You shouldn't have to touch the lenses as they're held by plastic moldings and I didn't unscrew or disconnect anything more. To get you started turn the long gear at the side slightly to move it from the closed position. If you have grit in there then you may need a SMALL amount of leverage with a flat head screwdriver. Clean the tracks and 'runners' as you go (don't apply any lubricant or it'll help future grit stick).
Once you've cleaned everything and reassembled it then it should run smoothly by rotating the long gear. If not then you may have missed something or the dirt may have caused more permanent damage meaning replacing a part.
Reassembly is the reverse of disassembly.
Hope that helps someone else suffering from this **** lenses system design.
Posted on Jun 08, 2011
How to slove system error(zoom) of my panasonic lumix dmc-fs15
You can't. it is cause by something blocking the gears or the lens being knocked to the side. Here is the online service form
http://www2.panasonic.com/webapp/wcs/stores/servlet/RequestCenter?storeId=15001&catalogId=11017
Jul 01, 2012 | Panasonic Lumix DMC-FS15 Digital Camera
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
When i turn on.it say system error (zoom).why?
might need formatted
could try calling the maufactoring company where you got it.
Aug 15, 2009 | Panasonic Lumix DMC-FS4 Digital Camera
Systems error (zoom)
there is a small gear on inside zoom lense that one not working chaing that part
Jul 11, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Help:D
At the start of a device BenQ DC E610, after the release of the target, the message "System Error 0010" will appear and the digital zoom will retract
Apr 28, 2008 | Cameras
System error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Listed Fix #4 might work for you. Place the camera on its back, and hold the shutter button down while powering on the camera.
Dec 21, 2007 | Nikon Coolpix 3200 Digital Camera
Panasonic Lumix DMC-FX100 Digital Camera Logo
258 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
