Philips 17056 shows me "Aging", what I have to do?
My philips tv 42pfl7422 has a white screen with AGING on it
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 11, 2016 | Philips Televison & Video
SCREEN SHOWS AGING MODE
What do mean by aging mode. If you think you monitor is going bad try to use another monitor in your system to see if you have the samer problem.
Mar 26, 2012 | Computers & Internet
We have 2 Nos Philips Rear Projection TV Sets procured in year 2004. I would like to confirm the effective useful life of these tvs as I am facing problems like convergence. Is there any aging effect on...
These tv's have an expected life of 8 years at normal usage so your tv's are starting to show signs of old age.
Yes, the failure of the power circuits in the convergence board are a common occurrence in tv's of that age. So common that other companies have started to put together refurbishment/repair kits for them. This is the one for this tv - Philips 60PP9363
http://www.tvrepairkits.com/xcart/product.php?productid=23618
Aug 04, 2011 | Philips 60PP9363 60" Rear Projection...
Press power on my philips 32pt6441/37 but power button flashes and no picture
Unfortunately, this is an aging tube type TV. I have repaired many of these when they were still in warranty. In your case you will be repairing the horizontal timing. You will replace a mosfet transistor (location 7404) an 8.2 ohm 2 watt resistor (location 3414) and a driver transformer (location 5402). If you feel you can repair this yourself, I suggest you order the horizontal timing kit with instructions. The number I give you may be obsolete. Don't worry, this number will get you a cross number to work with. Ask for part number 4835 310 57673 for TV chassis L04.1UAA. Thanks for asking and show all hands of support!
Jun 10, 2011 | Philips Televison & Video
Hello, my monitor (philips 170S) is going in "AGING . . ." when i turn ofg the pc..when its open the monitor keeps switching off and on constantly..none of the front panel buttons works while...
Open the monitor and chek with multimeter all buttons on the small PCB. (Front pannel buttons). On my Philips 170S the seccond button from left to right was defekt. Change the button and enjoy.
Jan 02, 2011 | Computers & Internet
Phillip TV show aging on screen
Your screen may need degaussing. The symptoms are colored blotches, usually around the edges of the screen. This is caused by magnetism in the screen itself . If this is the case a repair person can use a tool called a degaussing wand to remove the magnetism and fix the picture. Some TVs have the ability to do this themselves, it depends on the brand and model
Jun 21, 2009 | Philips TV Tuner Video Capture PCI Card -...
Remove data from Accounts Receivable / Aging Report
SOrry I'm not 100% sure of the incorrect calculation - Is this a reconciliation control error from Balances to A/R?
You will need to add the client back into your report as currently it is showing in one report and not another - giving you a difference.
Mar 11, 2009 | Avanquest ProVenture Invoices...
Philips 150B4 White Screen with the word Aging...
I have a philips 19 lcd. the damn thing just display a white screen with the word aging in red in the certer. it goes off after a while, turn black a while then comes back again, with the white screen. keeps doing it over and over.
anybody have any idea?
i tried caps, but all the caps look good.
to be noted i didnt change all.
Apr 20, 2008 | Computers & Internet
Phillips monitor 150b3 no dispaly just power on
monitor on position and display show "AGING..."
plz solution
urjant
thanx
Feb 26, 2008 | Philips 150B3T 15" Flat Panel LCD Monitor
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
