Question about Toshiba Satellite A105-S4004 Notebook
My Toshiba A105-S4004 will not hold its charge. AC adapter failed/replaced and no change. Replaced battery and lasted as long as the battery before powering down. Left plugged in overnight and new battery will not charge. Also cannot boot up when on AC power and battery removed. If this is a bios issue then I cannot update it if the laptop won't stay powered up. I did take it apart and reseated the hard drive and memory, cleaning as I went and reassembly went fine but no change in condition. Computer is 4yrs old and might be time to let it go since the symptoms don't appear to be hard drive related and I'll be able to recover files for transfer to a new system.
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 17, 2010
I have a Toshiba Satellite A105 laptop that will not power up.
Get sure the memories are good. then try reseting the BIOS by removing the BIOS batery, let it out for 5 minutes and place it again. Though you have to disassembly almost the whole laptop. If dont, chek the other "pheripheral" devices, HDD, DVD, and another (If)
Apr 20, 2010 | Toshiba Satellite A105-S4004 Notebook
Unable to start the computer. power button will light up for a second but no fans or other noises and then the light goes off
i would say try replacing the battery or the ac adapter. I had the same exact problem on my toshiba a105-s171. my battery was dead because the ac adapter failed to charge. Replaced the adapter and it works now.
Jan 18, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S4048 problem with AC Adapter When I turn the laptop on with the AC adapter, after checking the BIOS freezes and does not boot Windows. If I turn the laptop in only with battery boot...
There's not much you can do. The problem is definately with your motherboard. I'd recommend a bios update, but normally you can ONLY run a bios update if the battery and the ac are both plugged in.
This problem is pretty common among Toshiba's A105 and P105 models.
Besides replacing the motherboard there's not much you can do.
Sorry.
Mar 10, 2009 | Toshiba Satellite A105 Notebook
Dropped Toshiba satellite a105 laptop, screen black
If you pull off the top part where the speakers are above the key board your monitor might be unplugged. i had the same problem with one
Mar 09, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite a105-s4004 power problem
It sint the power jack, but rather the Power control circuit. This circuit isnt repaired but replaced. I recommend taking this to an authorised service center or a certified technician of the latter is not easily avilable. If you choose to repair this at your own risk please remember doing so without the necessary knowledge will result in major damages.
Jul 11, 2008 | Toshiba Satellite A105 Notebook
Toshiba a105
bad mother bord replace that bad power transiters on it not doing well and cpu getting hot may need new greese
Jan 21, 2008 | Toshiba Satellite A105 Notebook
Powering problem
yes i would say power is bad and maby battery best to buy both before going to replace mobo maby cooling dock they sell on ebay wont hurt ya ether
Jan 05, 2008 | Toshiba Satellite A105-S4004 Notebook
Laoptop batery
Try taking the battery out for 30 secs or so and then replacing it. You'll find a couple of locks on the bottom of the laptop that will release it.
Jul 10, 2007 | Toshiba Satellite A105-S4004 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
