posted by billiam69 on May 17, 2008
Machine will not drain. The pump is free and the motor tests good. Hose is not blocked. When testing without clothes in the washer it won't fill any more either , but I thought that might be because there are no clothes (it still has water that didn't drain out) so it might not be related to the draining problem.
Comment by billiam69, posted on May 17, 2008
Sorry, I should have said that it's a Bosch WFMC640SUC
1 Other User Has The Same Problem
Comment by Guest, posted on May 26, 2008
We did laundry most of the day. On the last load...it just kept going. It would not drain.
Solution #1
posted on Jun 03, 2008
Had the same issue. Just pulled the machine apart and found the exhaust/checkvalve was clogged with wash sludge. Incidentally, we have pets. Looking for the part as I type. Found something called a "ball sump". Does anyone know if this the same part?
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bosch Nexxt Premium WFMC6400UC Front
Email this problem
Email this problem
Can you Help with these Washing Machines problems?
Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch WFMC3200UC
Bosch WFMC3200UC
My Bosch clothes washer does... Answer This...
Bosch washing machine
My Bosch front load washer... Answer This...
Bosch Washer Nexxt 3200
The washer is not spinning or... Answer This...
bosch front loader washing...
bosch front loader washing... Answer This...
Washer help
Washer help
I have the Bosch 2060, Same... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
