Question about Nikon Coolpix 3200 Digital Camera
I ve not used camara for 6 months put new batteries in but it will not turn on .allen
  • Nikon Master
  • 17,130 Answers
Make sure that the battery terminals are clean and there is no crust in the contacts. Make sure the battery is of the same type/same rating for the camera to switch on.
If the camera does not turn on still, try to put the camera in a warm place for some time to ward off any moisture within. Repeat to ON.
If not you will need help to get the camera opened and checked within. The fault can be a simple link to the failure of the controller.
Posted on Sep 17, 2010
I have the same problem, the batteries do not last. Just bought new high quality batteries and put them in. The camara is already showing low battery and turn's itself off (just after putting them in,...
this occurs in any device that uses battery/s in some cases a small short forms that drains the batts there is only two fixs have the fault found by a service tech and repaired ( expensive and very hard to find) or store the batts out of the camera untill its being used now if the batts are not lasting in the camera then its the batterys simple. always remember with units such as camers always always use rechargable batts they give a heck of a lot more power drive than shelff pre charged batts
merry christmas
sonic boom electronics australia
please take the time to rank this advice below
thanks
Dec 24, 2010 | Fuji FinePix S3000 Digital Camera
Camara Kodak M1063 not charging
BATTERY MAY BE SHOT. FIRST MAKE SURE
ALL CONNECTIONS ARE TIGHT AND CLEAN.
IF THIS DOES NOT WORK, U WILL NEED A NEW BATTERY
Jun 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
My olympus isn't turning on
Try putting in regular batteries and see if it will turn on. The rechargeable batteries might be over-taxed and won't recharge. My Olympus camera works just as good on regular batteries as on the rechargeable ones. It is easier to come up with regular batteries than having to always run to the docking station to recharge the original batteries.
I hope this works for you.
Mar 20, 2009 | Olympus Camedia Stylus 300 Digital Camera
Battery warming up the camara
Was your camera working before you put the new battery? if yes, then its possible some dirt or grit has got stuck between the lens and the body and therefore you motor might be warming up.
Since you 've bought a new battery, I dont think It may not be the battery, the way you are explaining. It could be the lens motor itself, since its warming up.
Try to do the following: ( I 've got this checklist from the forum itself)
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
6: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Try the above and let me if its any help.
Best of luck
Mar 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Camara sony dsc-w80
First are you using a genuine Sony battery if not then get one. if you are it is a faulty battery pack and requires replacement, if under warranty take it back to the place of purchase
Nov 16, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Camara can't be turned on normally
I have to take out batteries and put them back a few time to turn on my camara in display or viewfinder mode. At first i doubt my battery's problem and replaced with new batteries, it was the same
Jul 18, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
My camara will not power up
the firmware is corrupted i think just take it to the technician & get installed the new firmware... it will work ...
Feb 11, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
CAMARA turns off when i press to take a photo
I have the same camera... and it was doing the same thing AFTER i changed my old batteries, because they were getting low. It was only after i put in the NEW batteries that i had this problem... I tried putting the old batteries back in and sure enough it worked again, so it probably all just depends on the brand of the battery you use.
Oct 09, 2007 | Fuji FinePix A500 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
