Question about Universal Remote Control Remote Control
Huayu universal dvd remote control what is the code for jvc dvd player. thank you
  • 54 Answers
SOURCE: im using the rca rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Posted on Aug 17, 2008
SOURCE: HUAYU HR-330E universal dvd remote code for
I have Elekta DVD player and I need code for universal remote. I have Hueyu hr-330e remote please help me. Thanks
Posted on Jul 09, 2011
trintek
  • 111 Answers
SOURCE: rca remote control code list
unfortunately i do not have a code for that specific model, you can however try the automatic code search method.
1) turn on the dvd player
2) press and hold the code search button, when the indicator light is lit, release the code search button
3) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
4) aim the remote at the dvd player and push the on/off/power button, there is a 3 second pause between codes, so keep the remote aimed at the dvd player
5) as soon as the dvd player turns off via remote, press and release the enter button
now to record the code for future reference..
1) press and hold the code search button, when the indicator light is lit, release the code search button
2) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
3) press and release the code search button, the indicator light should turn off
4) starting with 0, press and release each button in numerical order (0-9) until the light blinks, write down the number that caused the light to blink
repeat step 4 two more times until you have the 3 digit code. in the future you can use the direct programming mode to reprogram the remote if need be.
hope this helps,
trin
Posted on Nov 16, 2007
IrishDruid
  • 2712 Answers
SOURCE: program my remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 23, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
Code list for universal consolidator pm435s
Please check all links:
pms435 manual (to program) is here:
Universal Remote
http://remote-
codes.findthedata.com/l/163/JVC-Remote-Codes
codes:
Remote Control Programming Codes DVD http://remote-
May 06, 2016 | JVC XV-N312S DVD Player
Huayu...hr-133+ ID.universal remote 4 matrix TV.ty in advance.
    hr-133+id universal tv remote control use for tv by huayu
    www.aliexpress.com > ... > Accessories & Parts > Remote Controls
    $10.00
    Cheap control maintenance, Buy Quality control fuses directly from China control lan Suppliers: HR-133+ID UNIVERSAL TV REMOTE CONTROL USE FOR TV ...Missing: matrix
    www.aliexpress.com > Store Home > Products
    Find More Remote Controls Information about HR 133+ID UNIVERSAL TV REMOTE CONTROL USE FOR TV BY HUAYU,High Quality control maintenance ...Missing: matrix
    HR-133+ID - Huayu Technology Co., Ltd.
    www.huayu.cc/en/_XinWenZhongXin_v254.aspx
    HR-133+ID. Previous:Null Next:HR-159E · Enterprise · About us · Honor · Video · Contact us · Remote control · Amous Brand Remote Control · Universal Remote ...Missing: 4 ‎matrix images for hr-133+ ID.universal remote 4 matrix
Dec 28, 2015 | Televison & Video
Codes for JVC HR-XVC17
Refer to the instructions that came with your RCA universal remote. There should be a list of devices such as TV, DVD player, etc. Try to find your JVC device listed along with the code(s). If no luck, try using the code search routine described in the instructions.
Jan 09, 2014 | JVC HR-XVC17S
Huayu HR-2009E remote code
I have tried it on my DVD Player, its still not working yet.
Jan 21, 2013 | RCA Universal Remote Control
I need a remote code for a jvc dvd player
Hello
Setup codes for JVC DVD player with RCA RCR311W remote control are:
3144, 3353, 3357, 3407, 3408
OK.
Nov 20, 2011 | Televison & Video
Huayu RM-36E universal tv sets remote all code for konka tv
codes list for Universal TV set remote(HUAYU RM-36E+) for Goldstar tv
Aug 13, 2011 | Universal Remote Control Remote Control
HUAYU HR-330E universal dvd remote code for CG-D06OL dvd
Jan 02, 2011 | Universal Remote Control Remote Control
DVD remote Codes for a JVC XVN332
jvc xv n332 audio ok but no video how to unlock
Jan 01, 2010 | JVC XV-N332
Universal Remote Control Remote Control Logo
584 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
