Question about Casio Parts Cash Register PC Desktop
Flexion1. The keyboard orientation is different from the keypad template. The X multiply is located in button 4 under RECEIPT FEED and ERR. CORR/CANCEL is on button 3. Better if it will be back to the same location as per the keypad template. Will you please help and assist me on doing this AND of course the problem in amount limitation which is very important. Thank you.
  • 737 Answers
To change the keyboard, Turn key to program 4 SUBTOTAL 082 Now press the position where you want the X multiply button 034 Now press the position where you want ERR CORR button SUBTOTAL
as for the amount limitation, try it on the item that you set as 0 last time (3 SUBTOTAL 0 item SUBTOTAL). I need to know if it affects all items or whether any items you set as 0 above will work at less than $1.00. I don't think it has anything to do with training mode. Probably has a limit set from previous owner
Posted on Sep 19, 2010
Hi Flexion. You are right since the problem of not working ERR. CORR/CANCEL and X multiplication buttons existed since before (only noticed now) but the amount limitation error happens right after...
Sep 16, 2010 | Casio Parts Cash Register PC Desktop
Flexion1, Thank you for solving the problem E026 ENTER CONDIMENT/PREPARATION PLU. Please help me with the other; why is it that an amount less than <1.00 is not accepted to make a transaction, it just...
This makes no sense. they are all unrelated problems. Did all of these problems suddenly happen when you changed clerk settings? Try logging on as another clerk. They are in totally different areas of programming. I'm getting some information together for these problems. As for the amount limitation problem, do you get the error when you press the item, or only when you try to press CASH at the end of the sale?
Sep 15, 2010 | Casio Parts Cash Register PC Desktop
Flexion1, Many thanks for getting back to me. I guess better not to use the trainee instead. The solution did not solve the problem. Still the message E026 ENTER CONDIMENT/PREPARATION PLU appears on the...
Oh right. sorry, the last part of your question was cut off, so I didn't see all of it. It looks like you have accidentally set limitations and preparation status on a PLU.
Firstly, you need to jump out of preparation status. Follow this carefully:
Turn key to PROGRAM mode. (don't worry if error/ beeping) Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL and wait for printout. 3 SUBTOTAL (if you see error 8, you need to sign back on) 0 Now press the item button that gave you the error SUBTOTAL
Now go to REG mode and try that PLU (item). If it is doing it on any item or only when you press a payment, let me know
Sep 14, 2010 | Casio Parts Cash Register PC Desktop
Electroboy, thanks for your help. Can you please assist me with the first query with flexion1. I would like to know how to get the print-out on the receipt showing Quantity/Unit q'ty/@ Result rather than...
Sorry, I have just got back in the country. I think you need unit pricing during multiplication. This is held in one of two or three settings, so we can now go through and find it. In the machine feature programming section (just after keyboard programming), you'll find lots of tables with address codes at the top and then in brackets it will have a description. Look for the address code that has the description '(print control for receipt)' next to it. Tell me what the address code number is for that table.
Aug 07, 2010 | Casio Parts Cash Register PC Desktop
Flexion1: Casio Cash Register TE-2400 buttons
These three things are all non standard for cash registers and will require codes that I don't have. they can probably be achieved but it will require the machine setting tables from the manual to set the options. My notes are incomplete in this area. I can tell you what to look for if you are able to obtain the dealer manual
Jul 19, 2010 | Casio Parts Cash Register PC Desktop
You don't need to use the PLU button when operating in REG mode. The PLU button works like a flat PLU button except it allows code entry, so if you press flat PLU button 27, it is the same as typing 27 and pressing PLU. The PLU button is used to access the PLUs that aren't on the keyboard as flat PLUs. Since the machine has a lot more than the approx 70 flat PLUs on the keyboard, you would use codes and the PLU button to look up the others. The reason you needed to put the PLU button back was to allow us to use it in program mode where it is used to call up a PLU for editing (in this case to change dept link). The departments do not need to be on the keyboard. they are really just placeholders in the machine that total up the linked PLUs so you will only see them on your daily report when it has totalled at the end of the day. Try linking a PLU to a department as I showed you before. Then use that PLU in REG mode. Then do a daily report and it should show a sale in the department you linked the PLU to. I know it is confusing, but just link your PLUs at this stage and then you will start to see it happen as you use the machine and take reports.
Jul 17, 2010 | Casio Parts Cash Register PC Desktop
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Jan 26, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
94 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
