Question about Samsung (MP0804H) 80 GB Hard Drive
Hard disk pc hardware setup detacat but not format partisan message mbr number errr not reset mbr number not new partisan pls help my
Bad sector in your hard disk, format in win98 bootable cd
Posted on Oct 27, 2010
Vaio operating system not found.
first check that your hdd is detecting by your laptop.
i think you have removed mbr master boot record from your hard driver the soution is to create master boot record in your harddrive by using mbr commands.
May 06, 2010 | Sony VAIO VGC-LV110N PC Notebook
Tip
How to fix "Operating System Not Found" error when you start your Windows...
When you try to start a Windows XP-Based computer, you may receive an error message that the operating system is not found.
APPLIES TO
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
Symptoms
When you start a Windows XP-Based computer, you may receive one of the following error messages.
Error message 1
Operating system not found.
Error message 2
Missing Operating System
When you start your computer to the Recovery Console to recover functionality, you may receive an error message that resembles the following error message:
Setup did not find any hard drives installed on your computer.
CausesThis issue may occur if one or more of the following conditions are true:
The basic input/output system (BIOS) does not detect the hard disk.
The hard disk is damaged.
Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note Some third-party programs or disk corruption can damage an MBR.
An incompatible partition is marked as Active.
A partition that contains the MBR is no longer active.
Resolution To resolve this issue, use one of the following methods, depending on your situation.
Contact your hardware manufacturer
Your best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
If a fix or workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue.
Advanced troubleshooting
This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to contact Microsoft support, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/
Method 1: Verify the BIOS settings
Verify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk. See the computer documentation or contact the hardware manufacturer for information about how to verify the BIOS settings.
After you verify that the computer's BIOS detects the hard disk, restart the computer, and then test to determine whether the issue is resolved. If the issue is not resolved, or if the computer's BIOS cannot detect the hard disk, you may have issues with your hardware. Contact the hardware manufacturer to inquire about how to resolve this issue. You may have to replace the hard disk.
For information about how to contact hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
65416 Hardware and software vendor contact information, A-K
60781 Hardware and software vendor contact information, L-P
60782
Hardware and software vendor contact information, Q-Z
Method 2: Use Recovery Console
Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.
Warning This command can damage your partition table if a virus is present or if a hardware problem exists. If you use this command, you may create inaccessible partitions. We recommend that you run antivirus software before you use this command. We also recommend that you backup your data before you use this command. If the fixmbr command detects an invalid or non-standard partition table signature, the fixmbr command prompts you for permission before rewriting the MBR. The fixmbr command is supported only on x86-based computers.
For more information about Recovery Console, click the following article numbers to view the articles in the Microsoft Knowledge Base:
314058 Description of the Windows XP Recovery Console 307654 How to install and use the Recovery Console in Windows XP
on Jul 15, 2010 | Computers & Internet
Wiped old PC clean with blanco.installed win xp on old pc got response.turned it off black screen stating, blanco starting_ How do I fix
Blanco is a data cleaner utility that erases everything from a hard drive so data cannot be recovered. Unfortunately, this includes the MBR - or Master Boot Record. The MBR tells the comptuer BIOS how to access the hard drive and use it to boot up.
I would suggest performing a full FORMAT of the hard drive so the MBR will be recreated. If you are installing Windows XP from an install CD, you will be given the option of which drive to install the OS to. Delete all partitions that show up, create a new partition and then choose the Full Format option (not the Quick format).
If you are using a restore disk, you may need to download a boot floppy or CD and format the drive first. Boot to DOS, type in
format c:/
Where C: your hard drive.
You can get a boot disk from...
http://www.bootdisk.com/
Apr 30, 2010 | Computers & Internet
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
The computer is asking for me to restore mbr on the compaq computer corporation setup utility
Might be Operating System has been corrupted so pls repair the operating system through OS CD or re-install the OS .if still issue not resolve then replace the hard drive with goods one.
Nov 20, 2009 | Compaq Evo D500 PC Desktop
Acer Extensa 4630z won't reformate
Yes it is nothing to do with hardware problem of yours, here is a tip to install your windows xp on your ACER Extensa, but before that I tell you that your hard drive inside is Sata so this is the solution, go to your BIOS Setup and change the setting of your hard disk from SATA mode to IDE Mode, find it their., and have your installation with your new windows xp, trust me, good luck!
Jul 26, 2009 | Computers & Internet
Presario cq60 104tu
The master boot record maybe be corrupted or virus infected.
To fix the MBR, boot up with your DOS disk and type fdisk /mbr
Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
Feb 27, 2009 | Compaq Computers & Internet
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
Issues with my compaq armada
dear mitchiko
did you tried by changing the cables?if the problem still persists than it might be a problem with your motherboard.Contact your vendor then.
Apr 04, 2008 | Compaq Armada 1700 Notebook
Operating system not found on my laptop
ok i have had this problem.. (my computer would show the loading screen with all of the commands at the bottom. after this it would not boot up, but show a message on a black screen saying "operating system not found")
I completly tore down the laptop and making sure i had no issues with anything. so here is what i did that is simple and ended up solving the issues 3 times in a row.
1. take the cover off for the hard drive on the bottom of the laptop ( shows 3 very small disks beside each screw)
2. grab the clear strip that is on the hard drive and pull out the hard drive. ( blow out where it connects on the right side if dirty)
3. Reconnect the hard drive this will reset it.
4. Make sure to change back the processes to defaults when the computer starts back up.. If you fail to do so you will have to repeat the process each time you turn off the computer.
(This will only work if you messed up some settings while having the computer on, and not if you have faulty parts.)
for me i ctrl alt deleted and accidentally ended some important processes..
any other issues just email me at Bostelman@hotmail.com i will try to help you out. =D
Apr 03, 2008 | Compaq Presario 1692 Notebook
Samsung (MP0804H) 80 GB Hard Drive Logo
121 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
