Question about Hobart Dishwashers
Hi we have an under counter hobart dishwasher and we are getting an error message HEI and a spanner. they have managed to get rid of this error message but now it does not want to fill with water. does it just need a service? but it was recently serviced about 3 months ago
Master_Tech
  • 770 Answers
SOURCE: hobart commercial under counter dishwasher
Try this Link www.gcsparts.com They can fix it for you and they are good
Posted on Jan 23, 2008
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
bigg t
  • 640 Answers
SOURCE: dishwasher says delime on screen, how do i do this?.
Hold the delime button in and hit the on button for 5 seconds.It will then do a partial fill then it will say add delime,add delime shut the door and press the wash button.Let the machine do the rest it will turn itself off when finished.
Posted on Feb 14, 2009
bigg t
  • 640 Answers
SOURCE: Hobart dishwasher rinse buket filling water
Can you be more specific please?
Posted on Mar 11, 2009
bigg t
  • 640 Answers
SOURCE: Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
Posted on Nov 22, 2009
Hobart undercounter high temp dishwasher not heating water
am14 is not an under counter. Please specify what you have and is the issue is with wash or rinse heat.
Dec 31, 2013 | Hobart AM14C-155 Dishwasher
Hobart am15 scrolls message drain and de-lime with a constant beeping??
It may have reached the number of cycles to trigger a delime warning. Either follow the procedure in your operator manual to delime, or go into the control board settings and either change or turn off the delime timer
Dec 04, 2013 | Hobart 29 in. AM15-1 Free-Standing...
Hobart commercial under the counter diswasher LXIC Model Number 130016. DELIME light comes on every day at startup. Machine will immediatly run (in DELIME mode I think) for about 5-10 min and then get...
Q have your run a descaler . to rid the machine of its deposits . in order for the machine to run properly the parts and pump / screens must be clean . / descaling for deliming . dishwasher and icemakers is common practice . and then i belive the light will not come on . .. hope this helps mm feed back pls
Nov 22, 2010 | Hobart LXIC-6 Dishwasher
Dishwasher says delime on screen, how do i do this?.
Hi!
You need to buy a calcium lime remover/lime remover and if you can see a bad lime deposit then please buy a stronger delime.You need to put the delime in the unit and run it through a cycle.Repaet this procedure more than once to get optimum results & get rid of the scale. Also try and delime it once in a month or two so that this doesn't happen in future.
Please rate this solution.
Thanks
Rylee
Feb 13, 2009 | Jackson Dishwashers
Error message -E2
hi jim just push off button then on button then off again. this will drain off then go to restart mode. hope this helps.
Jan 06, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Bosch dishwasher malfunctioning
hi there,
check the drain pump, located inside under the lower spray arm for anything stuck in it.
do you get any error messages on the display?
Sep 23, 2008 | Dishwashers
Hobart dishwaser
hi,i just read your issue.im a hobart service tech and fix these units all the time.what model do you have and are you sure the error is bof?let me know,i can tell you all the info,error codes about hobart dishwashers.
Jan 14, 2008 | Dishwashers
Dishwashers Logo
139 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
