Question about Acer Computers & Internet
My @ symbol and " symbol is swapped around on keyeboard. How do i fix this?
What does "wrench" symbol mean in message center?
Wrench means, workshop needed. If it does not come back, no problem. If it keeps coming back, visit a repair shop.
Jul 17, 2014 | 2007 Mercury Mountaineer
My h20 symbol is lit up red
Sounds like the water filter needs changing only. What is your model number located around the fresh food section door frame? I will try to locate a user manual for you, Thanks Sea Breeze
Feb 04, 2013 | Whirlpool Refrigerators
Microwave sounds as though a motor is constantly running. Actually comes on when buttin pressed, runs about 20 seconds, smell odd, trips breaker.
From your description it is more than likely the magnetron has failed, the part replacement is the most expensive and can run as much as a new microwave oven in some cases.
Aug 29, 2012 | Amana RFS12MPS Microwave Oven
What if the screen is cracked? how do we fix it?
Send it back to manufacturer if they can fix it or else you are going to have to find one that somebody else broke and start swapping parts around. Whie the swapping is not really hard to do it does involve small parts and some knowledge on how these devices come apart.  Hope this helps
Jun 01, 2010 | SkyCaddie SG2.5 GPS Receiver
My computer is continually freezing everytime i restart it. how can i fix it. sometimes it will simply refuse to go through the startup and freeze after the original asus symbol is shown.
Freezing can be bad memory among other problems. Try removing a stick and see if you can boot. If not, swap sticks and try again.
Memory is not that expensive so buy more and try above.
Mar 13, 2010 | Computers & Internet
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Switched Keyboard symbols
Go to control panel on start menu.You may have to click Classic View. Click Regional and Language options. Click middle tab at the top called Languages. Click the Details button. Click Add and select the English UK option from the drop down list. Apply and Ok.
Mar 05, 2008 | Computers & Internet
The auto focus does not work
Try the Pentax tech support they may have an idea But if it is a board fault- will it be an economical repair proposition? They may also offer a 'swap out' option if it is an on going issue.
May 16, 2007 | Pentax *ist DS Digital Camera
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
