Question about Electronics - Others
No space, but memory stick is empty
I accidentally deleted the security password protected part on my memory stick, which was set on 100%
Now when I try to store data, there is no space, but the graph shows 100% empty.
How can I undelete?
  • danjs777 Aug 12, 2008
    When I try adding things to my memory stick it shows up as full because I deleted the security option.
  • Anonymous May 19, 2009
    Same problem. its killing me.
If your talking about your sd card lets say 4gb now says something like 92kb free, like all your memory just disappeared, then try this program it worked for me.
SD Formatter
Procedure to Install of SD Formatter
1. Install the software after finishing the download
2. Close all running programs on your computer
3. Run or Execute the installer file
4. Follow the instructions in the installation window
SD Formatter Manual
Posted on Jan 07, 2011
How to Recover my password protection manager when i accidentally deleted in sony 1tb external harddisk
Did you delete the program from YOUR computer, or from the actual Harddrive that stores your data? THe link to download is here and they also have support... http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-rme/sw_hdd_pwpm#supported_products
Dec 08, 2014 | Sony HDE1/B 1TB External USB Hard Drive...
Tip
How to Delete Protected Folders from a Memory Sticks
<p>Folder on the removable media used both FAT32 and NTFS file systems in Windows operating system. Some of these attributes in the rule of the people (name, size, creation date, and time) can be seen, others have explicit measures to ensure Windows. Among the latter are "read only" (if set, the folder cannot be erased) and "hidden" (if set, the folder does not appear in the parent directory.) A folder is set with one of these protected attributes clear. With a few extra steps, but you can secure a folder from a memory stick.<br /> <p> <br /> <p>1. Connect the memory stick for your computer. Windows will recognize it automatically and make your content accessible.<br /> <p><br /> <p>2. Click the "Start" and "run" (without quotation marks) into the search box. Click the "Run" link, type "cmd" and press Enter. A command window opens.<br /> <p><br /> <p>3. Type the following commands in the command window:<br /> <p> <br /> <p>E:<br /> <p>cd "\ myfiles \ projects"<br /> <p>Replace "E:"with the drive letter for the Memory Stick and replace "\ myfiles \ projects" with the full path to the folder containing the folder you want to delete protected. Press Enter after typing each line.<br /> <p>4. Type the following command to remove the attributes currently prevents you from deleting the folder:<br /> <p>attrib -r -h folderName /e<br /> <p>"Folder Name" Substitute the name of the folder you want to delete. Press "Enter ".<br /> <p><br /> <p>5. Delete the folder by clicking "Start", then "Computer". Navigate to the folder you want to delete, click once and press Shift-Delete. "Windows will erase a protected folder from memory stick.<br />
on Jun 21, 2011 | Computers & Internet
Is there any possibilities to recover the deleted files on the recycle bin after empty the recycle bin? What is the solution?
Yes, it is technically possible to recover any deleted file (Even those removed from the Recycle Bin) by using recovery software.
Check out how to recover deleted files from recycle bin from link blow.
http://www.asoftech.com/articles/how-to-recover-files-deleted-from-recycle-bin.html
Jul 02, 2011 | HP Computers & Internet
Why is my message always tells me that my memory is full delete some messages to receive new message, when my message on the inbox is only 5 sometimes less
Emptying the inbox is not all you may need to empty. Sent items, Deleted items, past calander events are all talking up space, might clean those out
Jan 20, 2011 | Computers & Internet
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
How do I clear the memory on a psp so i can access the internet?
  1. Empty your trash. If you have deleted saved files and have not emptied the trash on your device, you have not cleared up any memory--you have only reallocated it to a different part of the device.
  2. Step 2 Select "Home," "Settings" and then "System Settings" on your unit using your arrow keys.
  3. Step 3 Scroll through your "System Settings" options with the "X" button until you find "Format Memory Stick." Click "X" to select.
  4. Step 4 Choose "Yes" to confirm that you want to reformat the memory stick. The PSP will then reformat the stick removing all saved files and reformatting the stick back to its original memory space.
  5. Step 5 Plug your PSP or PSP memory card into your computer as another method of clearing your PSP's memory space. Once you have done so, select the appropriate drive letter, find the files you wish to delete and delete them as you would any PC file, or select "Ctrl" plus "A" to select all files and then click your "Delete" key.
this should do it for ya.. hope this helps ^_^
Sep 13, 2009 | Sony PlayStation Portable (PSP) Console
No memory space in memory stick
Transfer the images from the memory stick to your computer, make sure the transfer has been successful so you don't lose your pictures, then to be safe put the stick back into the camera and delete them once back in the camera. AGAIN, before you delete anything, make sure your pictures have been safely transferred to your pc and you can view them all. Deleting the photos from the stick will make the disc empty again and ready for more shots to be taken.
Jun 08, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Write protection on a Memory stick
mm? did you copy pasted or something in the right map of your stick, or did you delete something from ure stick accidentally?
Mar 21, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
128mb Sony Memory Stick Duo
            This is a common problem and its quite easy to resolve.
I had a very similar problem with a friends nokia 5200 memory stick , it refused access to the card , i got the message disk is write protected I couldnt even access it from a PC card reader or format it .
             Somehow he had accidentally set a security code for the memory stick and the mobile then forgot he had done it , I tried the usual code of 1,2,3,4 and this didnt work.
        When I tried the number 1 on its own , suddenly I could access the memory stick again and format it and didnt get the message (disk is write protected)...Reset your P800 security codes with the master reset function in the main settings menu.This will remove any codes that restrict access to the memory stick...
Sep 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Tried to password protect my Freecom 8GB memory stick. After the process which took about half an hour, the stick could not be accesses, but could by formatting. I did this and now the stick is only 8MB....
I'm not sure what you have done but.
Right click my computer
select manage
on the left side of the computer management window
see disk management
now on the right side where the disk management is open
find the usb drive from the list of drives, right click on all paritions of the usb drive and select delete partition, ones all parititons are deleted right click in the empty space and create a new partition.
it should work as normally, normal size.
Aug 11, 2008 | Computers & Internet
Electronics - Others Logo
845 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
