Question about Lexmark X5470 All-In-One InkJet Printer
I have a paper jam.i tried pulling out the paper but it wont budge.how can i do this without buying another one?
  • Lexmark Master
  • 19,396 Answers
Turn the printer on and press, the blue power button while gently pulling out the paper at the same time.Pull from exit side.
If paper is stuck at first rollers on entry side (paper tray at the back), then pull the paper out from the back.
If that does not work or if paper gets broken inside the printer, disconnect power, pull up the upper part (the one with scanner), and remove manuually paper pieces stuck inside the printer.
Posted on Sep 17, 2010
Printer is jammed. It grabbed lots of paper at one time to print and I can't get it unjammed...what do i do?
dear you should be for service centre becouse may be flack of paper jammed inside the printer if yo able to open printer so try . first cryout cartage toner then look inside printer or cartage. thanks
Apr 02, 2014 | Office Equipment & Supplies
I have a paper jam many pieces went through the printer and won't budge. I don't see a way to get to where the paper is stuck
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
My Brother MFC 7340 says it has a paper jam so open the fron cover and pull it out. When I do this the rollers don't move and the paper won't budge. I don't want to force it. What do I do?
Hello.
Try simply unplugging the printer from the power, then waiting 2 mins and plugging it back in while pulling on the paper that is stuck.
This sometimes helps
Regards GM
Jun 30, 2011 | Office Equipment & Supplies
I have a brother MFC 8440 and the document feeder has never worked properly. It pulls the documents in slightly off line and causes the paper to jam before it gets to the scanner. It is out of warranty...
you might have some type of foreign debris covering the paper path, you might want to try heavier paper (almost like a thin cardboard) and try to manual drive it into the paper path, do not force it too much if it wont budge.
also try cleaning your pickup roller, lint free cloth with iso-propel alcohol.
Dec 02, 2009 | Brother MFC-8440 All-In-One Laser Printer
Really bad paper jam
On the back of the printer is a access cover. You should be able to remove the jam from there quite easilly.
Aug 04, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Printer wont pull paper down then says paper jam
Dell does not make printers. They put their name on Lexmark printers.
I just repaired a 926 which had a paperjam alarm...and no paper jam. The paper sensor microswitch had been bent up onto a paper roller so the printer thought a piece of paper was stuck under it. It was hard to get the little lever off the roller and back, hanging free, without breaking it. This did not happen on its own so I can't fault the printer.
Look for this tiny black plastic lever hanging down right in the middle of the upper paper rollers, just behind where the carts run.
Jul 03, 2009 | Dell 926 All-In-One InkJet Printer
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | HP Photosmart C6280 Printer
Paper got stuck in printer
open the back and remove the paper gently. if there's any resistance, take your time. DO NOT attempt to pull it through from the front
Aug 19, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Re: Paper Jam
I'am sorry to say that you have to replace the fusing unit on that machine, when it jams inthe fuser like that the fusing unit is going bad. the fusing units range from: $200.00 to $295.00 plus service call. You may think about replacing it, sorry for the bad news. I've worked on about 5 of those machines with the same problem and it always comes down to replacing the fusing unit, even if you get the paper out it will jam again.
Nov 16, 2007 | Canon imageCLASS D761 Copier
Lexmark X5470 All-In-One InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
