Question about Sony Playstation 3 (PS3) Console
My playstation 3 will not connect to my tv with the av cable
    Problem Solver:
  • 16 Answers
Try this: 1. Turn it on so it has the green light 2. Then hold that button until you hear two beeps one after the other then let go and it should work. If it doesn't work try it but only with one beep.
Posted on Sep 17, 2010
How do you connect a ps3 to a Emerson 32" TV, with yellow, white, and red cords
your yellow is the video in, white audio left, red audio right.
Feb 25, 2018 | Emerson Televison & Video
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 won't hook up to my dynex tv with
Did you check the side of the television for the AV/Compsite ports (Yellow, Red, White)? A lot of models have these connections on the side of the TV. You did not list your model number so I cannot really check for you.
May 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
    Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
    3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    Canrt seem to get a connection from box to the tv.all wires are in correct .have tried the hold the button untill it beeps twice an still no picture. platstation 3 3-275772-01
    1. Make sure the AV Cable is connected to the AV MULTI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the AV Cable into the yellow port for video, and into the white and red audio ports on the back of your TV.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive ON/OFF button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the Standard Resolution (or detect the current display output settings of your TV/monitor).
    Jun 25, 2010 | Sony Video Game Consoles & Games
    Playstation 3 not showing picture when connected,
    the cable got a problem or the ps3 did...
    check it out at the store
    Dec 23, 2009 | Sony Playstation 3 (PS3) Console
    I need to know how to run my ps3 thru the optical wire to my hdtv
    Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
    You can connect your Playstation 3 to your TV in three different methods:
    1. Connecting with an AV cable
    2. Connecting with an HDMI cable
    3. Connecting with an Optical Cable
    Connecting with an AV Cable:
    1. You are supplied with a Composite AV cable which would typically look like the below image
    2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
    3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
    Connecting with an HDMI Cable:
    HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
    1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
    2. Connect the other end to the socket on the back of your TV which says HDMI IN.
    Connecting with an Optical cable:
    You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
    1. Connect one end of the optical cable to "Audio Out" socket on the console
    2. Connect the other end to the audio receiver.
    Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
    The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
    Dec 11, 2008 | Computers & Internet
    Playstation wont connect with av cable
    is it just the tv screen saying no signal? if so you may still have your tv in HDMI mode if not then you need to go into the television settings
    Dec 03, 2008 | Sony Playstation 3 (PS3) Console
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    23 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
