Question about Vacuums
CANT OPEN THE DOOR OF MY SAFE.NUTOOL S F 10 ELECRONIC DIGITAL SAFE
  • 377 Answers
You might find some help at this URL....
http://www.youtube.com/watch?v=IyGhEIbZLUU&NR=1
Posted on Sep 17, 2010
  • pwillitz Sep 19, 2010
    I am very sorry you thought so little of my SUGGESTION, never said it was THE answer.
    I searched the web looking to help you, found a URL that offered possible solutions and it obviously did not please you.
    My apologies for offering that suggestion.
Is it safe to use the cordless vacuum charging station in a horizontal position on a hardwood floor?
carol
say this by accident
by safe what do you mean./ we cant guess what you think
it must be stated.
1: safe for kids or pets.
2: safe and not burn down house.
or is this the horizontal worry?
endless , this topic, SAFE !
nobody can guess what you mean nor what safe to do what means.....
in some hands ,nothing is safe.
really
Dec 31, 2016 | Vacuums
CATHEDRAL ELECTRONIC SAFE 25EA CANNOT OPEN IT WITH MY CODE NEED THE RESET CODE
You can't, as there is no reset code available once the door is locked. It would be absolutely useless anyway if all a thief had to do was to ask on a public website for a bypass code. The only alternative way into the safe is via the override key (an actual physical key which fits into an opening hidden behind a removable plastic panel on the safe door).
If you cannot find the emergency key then you have just one fix: you must open the safe destructively. Fortunately, your model is just a budget-priced electronic strong-box rather than a true safe, so the top or sides can be easily be cut open using a grinding disc or by just drilling a few holes and joining them up with a cold chisel.
Note that it's not worth calling out a locksmith, they'll only cut the box open and the charge will be many time more than the cost of a complete replacement strong-box (you can buy a similar complete replacement for under £40 including postage from this seller).
Sep 19, 2011 | Vacuums
I have a micromark electronic safe at home but the battery is low therefore it woun't let me open the safe and i don't have the key
hi.
without the key, your options are very limited.
apart from destructive drilling, or expensive locksmith charges there may be one chance.
place a fan heater, or similar heater in front of the safe for 3-4 hours until the safe is warm to touch.
be careful not to cause a fire risk around the safe, or to overheat the safe. DO NOT leave unattended.
it will take this time for the heat to be slowly transferred to the battery compartment on th einside of the door, but when the batteries warm up, you may find they have a slight boost from the heat, and actually have enough power to open the safe.
there are no guarantees that this technique will work on your safe, as it is very dependent on the amout of life left in the batteries, but is worth a try as a last attempt before expensive drilling or locksmith charges.
good luck
Jun 09, 2011 | Vacuums
My e wave microwave appears to be in fine working order until the door is opened. It then trips the breaker and ceases working. Ater the house breaker is reset, the power is restored to the microwave...
You may have a short circuit on the INTERIOR LIGHT BULB circuit in your microwave.
This might explain why the breaker trips every time you open the door.
If so, you would have to unplug and disassemble the unit in order to access the wires and light bulb socket inside the case in order to troubleshoot and repair the problem.
If you are unfamiliar with safe electrical troubleshooting and repair procedures, please be extremely careful or consider hiring an electrician to do the work. There are some hazardous components inside which remain dangerous even after the unit is unplugged.
Good luck.
Apr 19, 2011 | Vacuums
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
I also have a hyundai electronic safe and I've forgotten my password. I know I need to push the center S button first but that;s all I remember. I have the serical number if that'll help.
The serial number is of no use. If you could obtain the combination simply by asking on a public website then your safe would be, by definition, an unsafe... Many electronic safes come with an emergency bypass key, so check that you haven't got one ferreted away somewhere.
If you have forgotten the combination and have no bypass key then the only option is to cut or drill the safe open. You can call out a locksmith if you like, but will find that the only difference is that he/she may have better tools and safety equipment than you and will have a better idea where to cut. Some cheap, pressed steel, safes with plastic front combination panels can be opened even more easily by just hammering off the plastic bits until access can be gained to the sliding door bolt mechanism.
Sorry that this is not the answer you were hoping for, but safes are not meant to be easy to open other than by using the correct key or combination.
Sep 24, 2010 | Vacuums
Cant find override key. can we open any other way CATHEDRAL ELECTRONIC SAFE 20EA
No. If you've forgotten the combination and lost the override key then all that's left is to cut the safe open with, say, an angle grinder.
Calling a locksmith out isn't an option: all they'll do is to cut it open and charge you at least £80 plus possibly the cost of a cutting disc for the service. It makes no economic sense when you can replace your safe for less than £30.
Note that as your safe is a really cheap and basic model with lots of plastic parts, you may even be able to smash it open by destroying the front of the door to access the door bolt mechanism. It's also not hardened against drilling, so you may decide to drill a pilot hole and then saw a hole into the safe.
Sorry, this may not be the answer you hoped for, but if safes were really easy to open without the keys/combination then they wouldn't be safe. Luckily yours is still very easy to open using basic household tools.
Please take a moment to rate my reply.
Sep 23, 2010 | Vacuums
Hoover Steam Vac Dual Rinse Model F7205-910
MOST COMMON PROBLEM IS THE ATTACHEMENT VALVE IS BROKEN WHERE YOU CONNECT FOR WATER ON SIDE OF MACHINE. THESE MODELS USE AN ELECRONIC SOLONOID TO ACTIVATE WATER TO NOZZLE IF IT IS COMING OUT THERE SOLONOID MAY BE BAD
Mar 27, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
208 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
