Question about Health & Beauty
I have a traveller 4 mobility scooter that sudenly cuts out and restarts after ive turned it off disegaged then reengaged the freewheel knob
    President:
  • 4,070 Answers
Hi! Looks pretty much a control switch failure. The circuit wire may be grounded or on the circuit board itself. You will need to have it checked by an electrician for this requires an on hand fixing. Hope this helps and have a good one!
Posted on Sep 17, 2010
Mother's scooter keeps dying
How old is the battery they don't last forever and they are not cheap
Sep 28, 2015 | Pride Go-Go Elite Traveller 4-Wheel Travel...
My boss has an Elite Traveller that won't move. The battery is fully charged and its in the unlock position. Please advise. Thank you in advance for your help.
  • When the manual freewheel lever is pushed forward, the brakes are disengaged and all power to the motor/transaxle assembly is cut.
  • Pull back on the manual freewheel lever, turn the Travel Scooter off, and then back on to return to normal operation.
Feb 01, 2015 | Elite Health & Beauty
My battery is charged, but my travel pro still won't run.
Is the brake lever in the correct position and not in freewheel mode !
Oct 02, 2014 | Pride Travel Pro 3-Wheel Mobility Scooter
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
Beep code 5 keeps going off, the manual freewheel lever is in the drive position. Can I repair it?
Hi remove the key for a short while make sure freewheel lever is in drive & replace key & try it out. If this doesn't help take key out put freewheel lever In freewheel then put it in drive put key back & try again good luck
Apr 13, 2014 | Pride Mobility Products Go-Go Elite...
How do I oil the freewheel mechanism located on the trans-axle
hi, is it noisy ? , i don't advise you doing that , they get noisy as they wear but in most cases they do not need to be open up , it';s tricky and i advise you to let someone who skilled in that to do so...
Regards
Rob
www.gewizrepairs.co.uk
Feb 23, 2014 | Pride Mobility Products GoGo Elite...
Scooter wont go beeps when turn the key on
Look at the freewheel lever on the rear of the scooter. Make absolutely sure it is not in the disengaged position.
Feb 03, 2014 | Pride Go Go Elite Traveller Plus HD 4...
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
5 beeps when turn on key
5 Bleeps -> The manual freewheel lever is in the(forward) freewheel position.Remove the key from the keyswitch, then push the manualfreewheel lever to the drive(rearward) position and restart yourTravel Scooter.
I strongly advise you to check the freewheel lever microswitch located on the side of the motor, also check the connection from the axle connection to the actual body were it comes apart. keep me updated please. regards GeWiz.
Dec 04, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
