Question about Nikon Science & Laboratory
I made a mistake: just left my Nikon microscopy continuing on for a couple days. Now I can't turn it on even I changed new bulb and fuse. I thought it could be burned inside, but I couldn't smell any burned-smell taste. Would you give me an ideal, what's happen on it? Thanks, Harry e-mail harryhfu@gmail.com
softplanway
  • 53 Answers
SOURCE: My Duet Whirlpool Dryer (had this #8519498) has burning smell
I am not the Dryer fixin' trade...but I have this dryer. To me, it sounds like it overheating or the heater unit has become lose from its hold rack. I would MOST definitely have a pro look at it and do NOT leave the dryer unattended...It may be a possible fire hazzard
Take Care
Wayne
Posted on Jan 03, 2008
  • 131 Answers
SOURCE: Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Posted on Feb 13, 2009
jvernice
  • 63 Answers
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Posted on Jul 29, 2009
SOURCE: Bad From Address while sending email from tally 7.2
how to do email from tall 7.2
Posted on Feb 11, 2010
fikretunalir
  • 238 Answers
SOURCE: Nikon SB-600. No power on / turn on even changed
Check these important points as shown in the following figures.
Posted on Mar 06, 2010
Turn signal/hazard warning/instrument panel lights not working
Has the dimmer control for the dash lights been turned off by mistake?
Mar 06, 2014 | 1997 Mazda MPV
2007 chevy impala brake light and left turn signal not working
Fast flashing dash signals mean there is a bulb issue-DEFINATELY!
Aug 07, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
When changing the rear taillight bulb, now the right blinker doesn't work and niether tallight work. I changed left and right bulbs
beth your central problem goes back many years. for some reason bulb makers thought it would be funny if two electrically different bulbs physically fit into the same socket. those where the 1156 and 1157 bulbs. if you have ever driven down the road following someone who had one very bright tail light and one dim one, then you have seen this at work. When the round sockets turned into flat blade sockets this nonsense was continued. what you have done there is inadvertently put the wrong bulb into the wrong socket. half the guys working in repair shops and all the guys working in gas stations and all boyfriends and husbands, except me, are unaware of this and make the same mistake. if you have a 50/50 chance to get it right, the odds are against you.
You need to do some thinking about what the socket is for, are there two functions going on such as a tail light and a brake light, and which bulb then goes into which socket. there will be two more or less the same in appearance on either side. a dealer cam most likely set you straight on this for free.
Apr 22, 2011 | 1998 Chevrolet Cavalier
Rear turn signal and hazard light don't flash (left side only)
The rear left turn signal bulb must be replaced immediatly before it melts the light socket, if it has'nt yet. Also please verify that the correct light bulb is being installed. because even though many bulbs look the same they are not identical. Installing the wrong bulb can be the begining of many, many problems in the particular circuit
Mar 26, 2010 | 2000 Ford Focus
LEFT TURN LIGHTS WILL NOT WORK ON 1993 TROOPER
believe it or not, a 4 way flasher can cause this even if it itself is working properly, otherwise flasher, bulbs, or switch is bad .
Oct 06, 2009 | 1993 Isuzu Trooper
1998 Chevy Cavalier Z24 left rear brake/turn lamps will not work
Sometimes even a new bulb will not work. If you have a Digital Multi Meter you can check that you have power going to the rear. I know that sometimes when a vehicle loses a bulb in one end that it can make the other end stop working. With that said, I suggest that you double check to see that the front works. I used to own a 98 Cavalier RS with the 2.2 liter motor and I know that there are fuses under the hood and behind a little door on the drivers side in the car. Might check fuses under the hood also.
Jun 09, 2009 | 1998 Chevrolet Cavalier
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Nikon Optiphot-2
You should start by changing the bulb, even though it looks ok chances are that it's no longer working. Do the same with the fuse if the new bulb doesn't work.
Test that power is reaching the socket with a voltmeter or a multimeter so ensure the wiring is ok with the new fuse. If no power is reaching the bulb socket, then you will need to check the wiring every step of the way.
Apr 18, 2008 | Science & Laboratory
Science & Laboratory Logo
164 people viewed this question
Top Nikon Science & Laboratory Experts
matt
matt
William McMath
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
