Refrigeration AC not blowing cold air
My Emerson AC is no longer blowing out cold air. It worked fantastic last year. It has not been used since September '07 until now. Are there parts that can be purchased and replaced to bring that cold refrigeration air back or am I out of luck and will have to buy a new one?
  • 828 Answers
If you can hear the A/C compressor start and run then your system has lost it's charge of refrigerant. If the compressor does not start and run it could be a control problem.
Posted on May 17, 2008
How come my AC is on but the air coming out is not cold?
Check the refrigeration lines coming off the outside unit. One should be very cold and one relatively warm. If one is not very cold, then the compressor is not working. Usually you can hear it when it is running. The condenser fan in the outside unit should also be operating. If the compressor and fan are operating, but the refrigeration line is not cold, you probably have a refrigeration leak and have lost the coolant. You will need a service tech for the repair.
Jun 02, 2013 | Emerson 1F95-1277 Big Blue 12" Touchscreen...
My air conditioner isnt blowing cold air
is the ac a manual one or automatic? if it's manual then it froze and will no longer work. it froze and is all done working. time for a new one. I bought one 12 years ago and apparently I was suppose to turn on and off. The ac couldn't do that. IF it works on it's own maybe the circuit isn't the higher amp for 220 ac units.
Sep 07, 2012 | tranexp.com Computers & Internet
Air conditioner not blowing cold air intermittently
you need a ac charge or the heater control valve is bad also check the compressor
May 30, 2012 | 2001 Ford Taurus
Air conditioner is not blowing cold air
Hello,if the compressor is engaging than the unit has dirty coils or has no refrigerant in the system.
May 29, 2012 | Emerson Quiet Kool 12HT13 Air Conditioner
Fan works but not blowing cold air
Is the compressor running? If it is then you are probably low on refrigerant and needs to be leak checked and recharged.
Jul 16, 2009 | Frigidaire FAC125P1A Window Air...
Portable Air Conditioning unit no longer blows out cold air
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Jul 01, 2009 | Heating & Cooling
Intermittent AC and Heat w/ long gaps of hot(for AC) or cold(for heat) air
I had similar problem on my 2001 Insight. Had to replace some cooling system hoses eaten by rodents... Works like a champ again.
Nov 03, 2008 | 2001 Honda Insight
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
