AC is not cooling
Problem #1:Outdoor condensing fan motor has stopped running. This problem
could be caused by a bad motor run capacitor. If
your motor capacitor is not the problem, then more than likely you need a new
motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard
to turn then you probably need a new motor.
Problem #2: Air conditioner compressor will not start. When power is applied
to the air conditioning outdoor unit the fan starts, but you hear a sound like
the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then
all you hear is the outdoor condenser fan run. The compressor is locked and will
not start. What is happening is the compressor is trying to start, but because
the compressor motor is locked it tries to start for a few seconds and then
because of the high amperage being drawn goes off on internal overload. The
internal overload protects the compressor windings from overheating and burning
up. I see this many times during the start of the air conditioning season. Some
compressors just have a hard time starting after sitting all winter long. Some
compressors are locked up so bad that I can not start them and must tell my
customer that they need a new compressor . Many
times I can get the compressor started again without having to buy a new
compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They
have saved many of my customers from having to buy new air conditioning systems.
