Question about Eureka 431A Optima Bagless Upright Vacuum
Broken canister latch
The little plastic latch that holds the canister in place ( the lower part that is recessed ) is broken. I need to find a new part to replace it. Cannot seem to find one so far...most site just offer replacement bags/filters....etc.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=604237
Posted by nestara on May 17, 2008
The little plastic latch that holds the canister in place (the lower part that is recessed) is broken. I need to find a new part to replace it. I cannot seem to find one so far...most sites just offer replacement bags/filters....etc.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Sorry you are having a problem with the replacement parts for your vacuum but if you contact the Eureka Factory Service line of which I will list below, they will either supply you with the part or give you a contact factory dealer that will get you the part and also you may as for a schematic or and owner’s manual in order to see how to repair the part. If you have further questions, feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
Rainbow e series will not turn on. Was working fine last time I used it.
There is a switch that is pushed in by a little plastic tab on the water tank when the machine is placed on the water tank. If the tab is broken off or the tank is not installed properly the vacuum will not run.
Sep 29, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Latches
Use a small punch and hammer to remove the brass pin holding in place. The pin has a smooth side and a rough side. The rough side bites into the plastic to hold the pin in place. Punch the pin from the smooth side to remove.
RainVac
www.rainvac.com
800-523-0510
May 14, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Upright self propelled Windtunnel model: The self propulsion does not work and I can see why. I need to know how to get the top cover off the machine to get to the broken part that engages and disengages...
First remove the bottom plate, brushroll, and belts. Three screws hold the top cover in place. One screw is in the center just behind the brush. The others are midway up on the sides - you may need a flashlight to see them. Once the screws are out, there are two latches on either side that secure the top cover, and these must be pushed outward with a flat screwdriver. Push one out to loosen the cover, and insert a screwdiver between the cover and the lower body to secure it while you push out the other side. You may want to remove the lower hose as well to make more room while replacing the drive actuating arm.
Jan 22, 2011 | Hoover Vacuums
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
On my Eureka Model 1759A (from mid-1980s), the plastic catch that holds the two parts of the metal body together has broken. I would like to replace the part of the catch that attaches to the top (the part...
This latch is riveted to the body. If you are lucky you may find an old Eureka warranty/ repair center with one on the shelf, or another canister for parts. That will be your best hope.
Oct 06, 2009 | Vacuums
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Canister problem
If it won't latch after cleaning the latch and making sure that everything is seated well, get in touch with Dyson, they're great about making things right with their vacuums.
Sep 18, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka 431A Optima Bagless Upright Vacuum Logo
269 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
