posted by Glebular on May 17, 2008
I have never been able to connect a video card to the TV. The video card output is DVI-D. The TV input is just DVI. I tried an adapter between the 2, and no success.
As a result, I've been forced to use a DVI-D to VGA adapter and sacrifice quality.
Does anyone else have this problem?
1 Other User Has The Same Problem
Comment by anerobic, posted on May 17, 2008
I have an acer 6920g laptop with a hdmi video output,it works connected to my hdtv except for the blueray player.Error code 0122 "incompatible graphics driver" comes up and stops play . many users report same problem,no answers on web yet.acer seems mystified.
Solution #1
posted on Jul 12, 2008
For error code 0122, Don't play the movie or load your movie program until you have the resolution you want and have it set to display only on the hdtv . You do this by going to control panel, selecting "adjust common used mobility settings", and then clicking on "connect display. A pop-up will come up and give you the option to display only on the external display. Pick that. The thing that sucks is if you have the display set to 1920 x 1080, you can't see everything on your desktop when trying to view it on the tv.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Acer AL2671W 26 in. LCD Television
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
flat screen turns green
seems our flat screen tv when... Answer This...
Acer AL2671W stuck in standby
Hi Tv Tech This Acer LCD TV is... Answer This...
acer 26 inch screen turning...
at first i had to keep powering... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
