Question about Soundstream DTR12200D Car Amp
Amp powers on but no output? the light is blue so that should mean good but no output ?
  • 625 Answers
Check the RCAs; make sure that they are connected properly at the amp and behind the radio.
Posted on Sep 17, 2010
Alpine pdx-m12 blue light fiashing
If the blue light is flashing it means the output mosfets are taking more than what the power supply can deliver. Probably just one of the MOSFETs is bad. Take off the heavy aluminum bar that is the heatsink for the 8 MOSFETs. Turn it on for about 10 seconds. (And see that the blue light is flashing.) Find the (hopefully) one MOSFET that is hot. Replace it. And you're good.
Aug 10, 2012 | Alpine PDX-M12 Car Amp
(I think) our bass player plugged from the output on a powered desk in to the input of our JBL MPro 18" sub (MP418SP) powered by crown Amplifiers. Now the fault light is constantly flashing and...
I'm assuming you mean he plugged an amp output (meant for a speaker) into the input of one of the Crown amps powering the sub-woofer. Right? Crown amps have good protection circuits and are high quality units. Some models have internal fuses but you didn't list a model here. If they are fused (or some kind of breaker) you should be able to see those by opening the top cover (amp off and unplugged). It is unclear if you tried to use the amp again after this incident.
Some Crown amps have protection circuits that will reset themselves after the fault is removed. In this case, you should remove both inputs and output (speaker) and power it up. If the amp doesn't light any protection lights or indicators, then turn it off and connect a known good speaker (not the subwoofer) and a source you can control. Set a low volume and see how it goes. You can really try either approach first depending on what's easier.
Jan 28, 2011 | Audio Players & Recorders
Amp's blue light is on but does not seem to send power to sub
It is possible that the set has gone into an error shut off. Please disconnect the power and allow it to cool off. remove the sub woofer connections if the amp does not turn on again. check for any short in the coils. reconnect the sources once again , making sure that the source is coming into the amp. If there is still no output, remove the cover and check if the main amp is shutting off due to any short in the output. You will need to confirm this out as you had run this a little too much in heat. replace the shorted mosfets if confirmed. hope you get this right. Good day
Jul 13, 2010 | Pioneer GMD7500M Car Amp
I grounded out the pos+ speaker output on my amp for a split second and the 3 external fuses are good what else could it be? even though the protection light is not on nor the power light but the inside...
if you grounded the pos sp out to ground it would have sent power into the internal ic units blowing them before the fuses could react time for a new amp sorry
Jun 19, 2010 | MA Audio HK1998 Car Audio Amplifier
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Lack of power, or bad amp?
Check your ground. Its just as important as the power supply. Take off any paint, good ground means good power, check the fuse on the amp and any connctions to the battery other than that i would exchange it
Feb 10, 2009 | Infinity 475A Car Audio Amplifier
Power
BATTERY CABLE TO AMP B+
GROUND CABLE TO AMP GROUND
REMOTE WIRE CABLE FROM AMP CONNECTS TO BLUE REMOTE WIRE ON BACK OF CD DECK.
RCA JACKS GO FROM REAR OUTPUT OF CD DECK TO LOW FREQUENCY ON AMP INPUT.
Check Power cable fuse, check ground is grounded to non painted surface.
This is all you need to get it to work. If you still have a problem, then it is a bad capacitor inside the amp
Jan 30, 2009 | Car Audio & Video
Trouble shooting XM-1652Z Amp
Grab yourself a test light and make sure that not only the 12v red power wire is putting out power but the thin blue or 12 volt turn on wire is also showing power. Then test the ground terminal and make sure u have a good ground. If that doesnt work try checking the amps fuses and check the fuse and connection on the battery. If everything checks out ok and the problem persists then put a small test speaker to the channel outputs and make sure that u are getting noise from those channels if you dont get any noise then u most likely have bad outputs and blown channels, you will need a new amp. Good luck, hope i was good help.
Jan 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Soundstream DTR12200D Car Amp Logo
57 people viewed this question
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
