Question about Kenmore 21.7 cu. ft. Top Mount Refrigerator w/Factory Installed Ice Maker
Bottom not cold enough
Top does freeze, but not enough to keep ice cream; however milk and ice cubes do freeze... the bottom is not cold enough. I have unplugged, cleaned out in back etc... and replugged about 5 hours ago... still not working properly... what now??
    Genius:
  • 1,073 Answers
Did you remove the back freezer panel ? if not need to
is there a large anmount of frost on the coil behind the panel?
if there is thaw the coil with a hair dryer
if there is no frost on the coil you have a sealed system problem that will nee to be taken care of by a tech
if frost is on the coil you have a defrost heater defrost thermastat or defrost timer that is bad
Posted on May 17, 2008
How do you make iced hot chocolate?
  1. Pour milk into blender.
  2. Add hot cocoa mix and ice.
  3. Blend first at low speed and then high speed until ice is finely crushed and slushy.
  4. Pour into tall glass and top with whipped cream and a dusting of hot cocoa mix, if desired.
  5. Serve with a straw and enjoy!
  6. P.S. This recipe was originally posted using small ice cubes. At our shop we have a commercial blender that has no problem getting through these. Since most people have regular blenders, I have changed it to crushed ice.
Feb 25, 2013 | Wine & Spirits
Do you have any recipe for milk free ice cream? For lactose intollerant diet?? Perhaps Almond Milk or Soy Milk.
Here are some of the useful steps to make a milk free ice cream.
1.) Microwave the chocolate and butter-substitute for thirty seconds in a microwave-safe bowl.
2.) Add a dash of salt, and a splash of vanilla extract to taste.
3.) Put a scoop of marshmallow fluff into the bowl and stir it in thoroughly.
4.) Remove the spoon, lick it clean, and wait up to 5 minutes for your mixture to become room temperature.
5.) Place it in the freezer for 50 minutes, remove, and if it is still not frozen well, then stir it thoroughly and place it back in the freezer for another 20 minutes.
Jun 26, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Westinghouse RJ275M 194l fridge with top 81l freezer doesn't keep the fridge cold anymore. Freezer is fine. is it the thermostat?
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
Nov 25, 2010 | Westinghouse Refrigerators
Doesn't freeze consistently
Here is a tip that will give you the information you are looking for...
Ice Cream Maker Parts, Instruction Manuals and Recipes
http://www.fixya.com/support/r5322664-ice_cream_maker_parts_instruction
heatman101
Jul 13, 2010 | Rival 8704 4 Quart Ice Cream Maker
Why is my ice cream not freezing, used it last winter, following the same recipe and instructions but it is a milkshake consistancy
I had this problem when I decided the salt wasn't necessary on the ice that chills the container. The salt lowers the temperature so that it is cold enough to freeze the milk. Try more salt on it.
Jan 06, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
What's the recipe for coffee ice cream
Ingredients:
  • 2/3 cup sweetened condensed milk
  • 2 tablespoons instant espresso powder
  • 2 tablespoons espresso liqueur
  • 1 1/4 cups heavy cream
    Put the condensed milk in a bowl and stir in the espresso powder and liqueur. In a separate bowl, whisk the cream until it reaches soft peaks. Fold the cream into the condensed milk mixture, then pour this gorgeous caffe latte-colored airy mixture into an airtight container and freeze for 6 hours or overnight. Serve straight from the freezer.
    This is the best procedure to make a coffee ice cream.
Sep 17, 2009 | Ice Cream Makers
Not getting cold enough to freeze popsicles but is making ice cubes
water freezes at 32 degrees. ice cream needs to be below 0 degrees to remain firm. your freezer is nort cold enough. ;)
Aug 12, 2009 | Freezers
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 21.7 cu. ft. Top Mount Refrigerator w/Factory Installed Ice Maker Logo
320 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
