Question about Philips 42PF9946 42 in. EDTV-Ready Plasma Television
When tv was switched on this morning the colour seems all blury/mixed, also has a problem with volume sometimes goes and we have to press a button on remote for volume to reappear, any ideas please
  • 7 more comments
  • joshriza Sep 22, 2010
    i have a flat screen tv philips 42 inch PF9946/12 i understand the problem could be called solarization could you please advise what is nessesary to repair this item ,the tv has a weired colour effect on the sreen although the chanels are showing the colour is faulty
    hi ladywinn thats the sort of technical support i expect from this sort of service not as previous thanks alot i have something to lookfor only thing i may not be able to buy the parts from the states ,i may have to order from uk you know vat and all that regards.
  • joshriza Sep 23, 2010
    to try and keep it short the main cable tv if you like comes in from virgin cable into set top box from set top box ,ariel cable from ariel booster to tv , tv to philips vidio/dvd player,dvd/vidio to tv, we have 2xscart leads connected to both points on tv that go to set top box and dvd/vidio units, however i cant see what differance this makes as the tv has been working fine for 5 years, the connections are all ok i have checked, leads ok the booster is working and the out side ariel is fine ,watching the tv this morning the screen is almost flashing, i have also disconected all units from the tv and went through the reset progame with philips help line , i think something is definately wrong with some internal part which needs replacing or some soldering of existing points thank you for any advice all appreciated in advance
    thank you for that i notice this morning the tv is almost flashing or pulsating so it seems to be getting worse ,i think its time to open up the back and have a look something is definately wrong back their, the tv is not switching on so quietly either at the moment thanks again
    I HAVE NOT OPENED THE BACK OF TV AS YET ,
    thank you for your help in the matter
    thank you again for your help in the matter i will let you know than you
    hi there me again i have done the carinal sin ,i have removed the rear panel ,i have sucked up the dust looked at all soldered parts to the large central board and the 2 either side they all seem fine without pushing or pulling at them of course all the small white fuses seem in tact, i noted 3 green lights when put tv on on main central board ok, then i noticed a small green flashing light in the area behind the top section where the conections to the plugin items are inotherwords on the board directly under the top board would this light flashing be a signal to damaged area i wonder it seems involved to get off any ideas thanks .
    interestingly i just noted that there are 2 x sockets like telephone conectors 1and 2 headed service, i find it unbeliveble that the technitions i have spoken to have not said anything and have asked for £50 call out and then to take the tv away when all they need to do is plug the unit in and read the fault unbelievable talk about money making
  • Philips Master
  • 5,138 Answers
Problem will be in the Main Board its the board that has your cable connector and AV input Jacks on Call Encompass Parts Distribution ask if they have it in stock 1-800-638-3328
Posted on Sep 22, 2010
  • 3 more comments
  • ladywinn
    ladywinn Sep 22, 2010
    You can try taking Main Board out and resolder all the tuner pins and around IF circuit and any place that looks like a poor solder connection
  • ladywinn
    You will need to have a soldering Iron and Solder
  • ladywinn
    ladywinn Sep 23, 2010
    Let me know if you need any more help with your TV.I sometimes Look on EBay for Parts ,I have found them cheaper then what alot of companys want for them. Look under Electronics/TV Parts.
  • ladywinn
    Here Service Call Charge is $100.00 ($50.00) to come to your house and $50.00 to check out TV.
    When I Make Service Calls ,I try to fix them in the Home at all cost to aviod having to take it in,
    Most of the time I am able to do this if I have the Parts on hand and its a Fix and Go Repair.
    Theire has been a few times when It was a Time consumming repair requiring more then an hour of work,then I have to try to bring them in shop .But trust me I had much rather fix it in the customers home then to bring it in. I made one service call and when I arrived at customers home and saw the TV 60inch Sony Big Screen projection and the long steps to front Steps leading to Front Door ,I went back outside to Truck and told helper that if we cant fix it here ,he will have to call someone Else. This was a Doctors Big House!
    Any Good Repair Shop should always do their homework on Customers set before going to Make Service Call and carry with them the Parts they think they will need for that Make and Model.
  • ladywinn
    Does this set have the T-Con Board in it ? I cant seem to find a Service Manual on this Model.
    I know in some models they have T-Con board and if they are defective it will cause off color and picture.
  • Philips Master
  • 5,807 Answers
Thanks in advance for choosing Fixya for assistance,
I would like to know what input are you watching from?
Is it from the TV built in tuner or from an external tuner
with TV connections to RF Antenna or Audio Video In
of your TV.
Have you tried connecting your TV to other sources?.
just to conclude that the problem is the TV ?,
like a camera or VCR or similar to the
TV Audio and Video IN
Awaiting for your immediate answer to begin helping you.
Posted on Sep 23, 2010
  • 8 more comments
  • Rommel Cana
    Rommel Cana Sep 23, 2010
    At the back of your TV the chassis number is printed on it, you may have to post it
    Inside the TV ,( if you have already open it ) you can see the VS and VA voltage setting for your TV
    you can also post these or not.( printed on a sticker on the chassis )
    Here are initial thing to do ( If the unit has been open already )
    we will have to start with all the Power Supply Output Voltages just to confirm ,
    if it all have the necessary voltages to the drive( Vs and V a ) other circuits on the other Boards.
    What I am referring are the DC to DC converters on the power supply, you should have
    the 3.3V supply for your Y drive Board and other output voltages and post what you found.
  • Rommel Cana
    or you can send a link where i can view images shown on your TV
  • Rommel Cana
  • Rommel Cana
    here is a sample sticker you can see at the back:
  • Rommel Cana
    and possibly later you might see something like these or
    similar to your board:
    http://flattvparts.co.uk/index.php?main_...
  • Rommel Cana
    • these is in reference with your quest:
    " i think something is definately wrong with some internal part which needs
    replacing or some soldering of existing points "
  • Rommel Cana
    • And unless there are 3.3V output on the Power supply Y drive wont work ,
    and there will be no picture It could also be from the oscillator circuits.
    which drive the MOSFET s
    How to test MOSFET
  • Rommel Cana
    here are some additional info:
  • Rommel Cana
    thanks likewise for choosing Fixya for assistance
  • Rommel Cana
    thanks, and may God Bless you!
    President:
  • 2,777 Answers
It sounds like this TV has some fairly major hardware issues going on here. Does this problem persist regardless of what input you are on? When watching regular TV / DVDs, and anything else you may do on the TV? It all has an issue? Sounds like you could have display board failure inside the TV... and the volume issue is very strange. You are certain you aren't hitting that "button" in question and it makes the volume disappear? If not then I would suggest you may want to start looking into replacing this unit. Is it in face the Philips 42PF9946?
Thanks much,
Tim
Posted on Sep 21, 2010
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
I keep getting different colours on my screen red, yellow, pink and blue i pressed the self focus button so many times it does'nt seem to help it clears it while the self focus button is on and then it...
This is Because of the wire is not connected properly chaeck the wires >> unplug and replug them if there are any screws please tighten them
or replace the cord
Aug 15, 2008 | Televison & Video
After pressing power lock key for 15+ seconds. The screen goes dead. Almost immediately the word Google comes up followed by a pattern of colours. The Nexus will not reboot
Have you tried using the reset key sequence?
Hold down volume up or down, then push and hold Power button until it enters recover. Release buttons. Volume chooses option and power selects option.
Feb 12, 2015 | Tablets & eReaders
Volume is at MAX every time i start my Samsung TV LCD LA37A550P1R
Check your manual for resetting the TV to 'Factory Default'. I have heard of this happening before. It may need you to press a combination of buttons on your remote. Usually you have to be pressing the buttons in sequence with the TV in standby, then wait for a service menu to appear. Look through this menu for the words 'Factory Reset'. It may be in a sub menu. The TV may well switch itself back off and then on again. At which point your problem should have gone away.
Dec 21, 2013 | Dell W1700 17 in. HD-Ready LCD Television
TV volume goes to loudest on it's own
It sounds like you may have a stuck micro button (volume button on tv) . You might try to push the up volume button on the tv several time and try to get it unstuck (if in fact that is the problem). Also sometime I have had situtions where the board holding these switches on the inside of the t was broke and had to be soldered and repaired.
If I can be of any more help, please email me at wyoed1@aol.com. "Original Radio Man" Ed
Feb 12, 2013 | Sharp 25R-S100 25" TV
TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Jul 19, 2010 | Philips Televison & Video
Magnavox tv model ts 2543 c121 volume control goes to high and you can not lower it..when you do it goes right to high
does the volume indicator on the screen appear?if it is then you should clean the volume buttons of your tv use a contact cleaner to clean the volume switch .spray the cleaner on the buttons and repeatedly press the buttons to clear the poor contact.
Jun 13, 2010 | Televison & Video
My volume button goes all the way up to the max and stays there and sometimes my mute won't work how do i fix the problem
It looks as if your volume up button is stuck, either on the TVs manual buttons or the volume up button from the remote. To check if it's the remote, put the remote away from the TV, either in a drawer or take the batteries out. If the same check the Volume up button on the TV, it may be pressed down & stuck in this position. If this is ok most likely the volume button will be at fault & need replaced.
Jul 13, 2009 | GE 31GT660 TV
Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Jun 14, 2009 | Vizio L37 Television
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Philips 42PF9946 42 in. EDTV-Ready Plasma Television Logo
159 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
