Question about Sharp AR-M205 Copier
Sharp copier - AR266-FG call for service code H3-11
  • Sharp Expert
  • 316 Answers
H3-11 -Heat roller high temperature detection
Posted on Sep 20, 2010
What does service code 62-05 indicate on a sharp mx 850 copier?
The best that I can do for you with tyhis question is refer you to the following link on FIXYA! ;
What does service code 62 05 indicate on sharp mx 850 copier
Dec 05, 2014 | Sharp Office Equipment & Supplies
Sharp MX-2300N Maintenance Required: Code VC
Time for some scheduled maintenance! Call a local sharp dealer.
google sharp service locator, enter your model and your zip code to find a dealer near you.
Copier Collin Houston TX Copier and Imaging Expert
Jul 11, 2014 | Sharp MX-2300N Color Copier
WHAT IS THE SOLUTION FOR DVCAM ERROR CODE 09-224 AND 09 -824 RESPECTIVELLY, PLZ IM VERY IN FOR THAT NOW . FOR THE DVC MODLES 2000AP &1800AP.
The error 09:824 Failed to detect the threading FG during unthreading.09:224Failed to detect the threading FG during threading.For this what u have to do is,clear all the Error in ur Eprom IC.So go to maintenance menu and service Support.then check the FG function.in that way it solve ur r problem
Apr 05, 2011 | Sony DSR-1800 DV/Mini DV VCR
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Jun 02, 2009 | Sharp AR-M205 Copier
SHARP AR 651 SERVICE CALL
what is code nomber please send me
Jan 13, 2009 | Sharp AR-651 Copier
H-3 error code in a Sharp ARC260m
The analog Sharp copiers used the crop code (clear, repeat, zero, pause).  Once the digital models came out the rules changed.  Sim 14 was for the analog copiers as well.
A good resource to get the answers you need is copytechnet.com.  They have Sharp copier technicians on there who can help you with the problem.  Unfortunately I only work on the low end Sharp models (for their product line).  The service codes are different on that machine. Copytechnet is a free service and they only deal with copiers.
Oct 03, 2008 | Office Equipment & Supplies
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Sharp AR-M205 Copier Logo
211 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
