Question about HP cp1700 Color Inkjet Printer
I have troubles in reading the messages in the display because some lines are missing. At the moment the printer does not work, because I cannot read the error mesages in the LCD. I tried hard to find solutions and after calling HP Support I was told that spare parts are not more available. Now, i become a little bit desperate because this printer is needed frequently. Ink Catrtidges as well as Printer heads are ok. How can I get running the printer so that its works properly? Hubert Maier A-4210 Gallneukirchen Austria
  • 10,515 Answers
I read the question.However, as you cannot see the error message, it is practically impossible to diagnose the problem. Regarding the spare parts, there are many options and ways to get that. However, first of all we need to know the exact error message. There are many different errors and it is not a wise option to keep swapping or replacing parts.
There are many problems that needs repair and is advisable that you should replace printer than repair it. Even if you spend many bucks on repairing the printer so that you could read the message ( obviously as few lines are missing, this is indicative of hardware fault ).
If you want parts, you could buy a non working printer ( same model - used ) from :-
http://cgi.ebay.com/hp-color-inkjet-printer-cp1700-/250696571122?pt=BI_Toner&hash=item3a5eae18f2
As i mentioned you could try swapping, however it would be a gamble.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 17, 2010
Reset maintenance count
T632 reset maintenance count: Press and hold down the "select" and "return" keys while powering on the printer, hold these buttons until the display reads " 80 Scheduled Maintenance, press the "go" to continue past this message and access the configuration menu. Press the menu button until the display reads "reset Maint Cnt" on the second line of the display and press the " select" button. the top line of the display should nnow read "reset maint cnt" and the second line will read "reset" and pressthe "selcect" button. this will reset the counter to exit out of the "configuration mode" cycle the power.
Jan 16, 2014 | Lexmark T632 Laser Printer
T630 clear counter
The following will reset the maintenance count after you install the maintenance kit, you can not reset the printer total page count. Press and hold down the [Select] and [Return] keys while powering on the printer, hold these buttons until the display reads "Performing Self Test." If the display readds "80 Schedules Maintenance", press the [Go] to continue past this message and access the Configuration Menu. Press the menu button until the display reads "Reset Maint Cnt" on the second line of the display and press the [Select] button. The top line of the display should now read "Reset Maint Cnt" and the second line will read "Reset" and press the [Select] button. This will reset the counter. To exit out of the "Configuration Mode" cycle the power.
Apr 15, 2013 | Lexmark T630 Laser Printer
How to reset the meter counter after replacing the fuser assembly on hp8150 laserjet printer.
Here is the step by step guide to resetting that message.
Reset the "Pages Since Last Maintenance by using this procedure:
  1. Turn off the printer.
  2. Hold down the left side of the ITEM and VALUE keys at the same time.
  3. Turn on the printer.
  4. Wait for RESET MAINT\\COUNT to display, and then release the keys.
  5. Allow the printer to initialize normally. The display will read "READY ".
Turn off the "PERFORM PRINTER MAINTENANCE message by following these steps:
  1. Press the MENU key until the display reads CONFIGURATION MENU .
  2. Press the ITEM key until the display reads MAINTENANCE MESSAGE=ON .
  3. Press the -VALUE+ key once. The display should read MAINTENANCE MESSAGE=OFF .
  4. Press the SELECT key to put an asterisk by the setting and save it.
Mar 18, 2013 | HP LaserJet 8150 Printer
How do I stop the message of 'Missing or damaged cartridge
Delete and reinstall a printer driver and then go into the protery of the new driver and search for update go to inksell.com they will give you the latest driver
Jun 03, 2017 | HP Officejet Pro L7680 All-In-One Printer
My printer reads cover open however the cover is closed. this error message occurred after the ink was changed. What am I missing?
Why don't you turn off your printer and restart.
What's the error code? There should be some letter on LED display.
Apr 11, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a brother printer MFC210C that has a error code A7 unable to INIT
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Mar 03, 2010 | Brother Network Ready All-In-One InkJet...
T8008 printer with message says "replace fuser"
The 'Replace Fuser' message on the 8008 can be cleared in the following way;
• Power the printer Off
• Hold down FORM FEED and ENTER and power the printer on
Keep the FORM FEED and ENTER keys held down until the printer displays SERVICE MENU - INFORMATION
• Press the RIGHT ARROW to MAINTENANCE, and press ENTER
• The Display should read MAINTENANCE - CLEAR FUSER, if it does not press the right arrow until it does and then press MENU/ENTER
• The Display Should now Read CLEAR FUSER NOT EXECUTE, Press the right arrow until the display reads CLEAR FUSER EXECUTE
• Press ENTER, and after a pause the display should read COMPLETED CLEAR FUSER
• Power the printer off and after about 10-15 seconds power the printer back on again.
The message should now be cleared
Jan 12, 2009 | TallyGenicom 8008 Laser Printer
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Oct 26, 2008 | Office Equipment & Supplies
HP cp1700 Color Inkjet Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
