Question about Konami Silent Hill 4 for Windows
Silen hill 4 The room won't open in Windows 7 Professional 64bit? I Don't get any errors at all. i am goign to look at the event Viewer. but it saysWindows cannot access the specified device, path, or file. you may not have the appropriate permissionsn to access the item. "
The Room does run on Windows 7 64-bit.
I just played a pirate copy of The Room on mine, to make sure a purchase of the proper boxed game is not an unplayable waste.
It worked fine after a minor adjustment to setup.reg and so should the real DVD, if that is what you are using. My version of Windows 7 does not even, to the best of my knowledge, come with the virtual XP.
These are the instructions I followed:
"Hey world's people, if your pc is say: ''Game not installed correct'', Thats why:
-You're using a Windows Vista 64 bit or Seven 64bit
-So just follow the following steps:
1. Click in the setup and install.
2. After setup is over, open Setup.reg with notepad,
3.Replace the line [HKEY_LOCAL_MACHINE\SOFTWARE\Konami\SILENT HILL 4\1.00.000] with [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Konami\SILENT HILL 4\1.00.000]
4.Save
5.Double click the setup.reg file again and click YES!
6.Enjoy!!"
Posted on Jul 29, 2012
    Novelist:
  • 151 Answers
Hello ez0469
Silent Hill 4 doesn´t run on Windows 7 Professional 64-bit. This edition of Windows has an in-built virtual XP machine, which I would recommend installing the game on.
To access it, press the Windows key and type in "XP", and it should be one of the first hits in the results list.
When you now launch the game, the virtual machine will automatically load in the background.
Hope this helps. If you need further help, please feel free to ask.
ajblaj
Posted on Sep 17, 2010
  • Kemal yldrm
    Kemal yldrm Feb 05, 2015
    ?at da fak ap meyt
    New Friend:
Snipars will rek you all guys
Posted on Feb 05, 2015
SOURCE:
Google chrome will not open on my computer, I have defragmented and used troubleshooter. I also tried uninstalling and then reinstalling it
Best place to look is your event viewer for clues as to what is going on.
Usually you can find it in Control Panel > Administrative Tools
Open the Event Viewer and choose the "Application" option.
Tip: In Windows 7 it might be under "Windows Logs"
Once you have that open, scroll down and start looking for warning and error reports related to google chrome or events that happen at the same time as you tried to run it.
That should then provide you with EventID's and error messages to use as search terms/phrases and narrow down the likely causes.
Hope that's of some help.
Jul 31, 2013 | Acer Computers & Internet
Computer Event Register
Search for 'event log' or 'event viewer' in Windows 7, xp, vista
I don't know about Windows 8 or Apple Safari
Generally the event log registers each event... and if enough certain error types accumulate within time frame parameter, the computer issues error message.. or contacts the server at Microsoft possibly signaling need for update etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 28, 2013 | Computers & Internet
HP d220 mt won't boot from a windows 7 install DVD....Will boot an XP install CD
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
Nov 28, 2012 | Computers & Internet
Iolo system shield will not scan
im not up to speed with this type of error or what its associated with
if you want to know what this is the error code is related to
click start control panel system and security administrative tools computer management then select event viewer this may vary depending on what operating system you have
hope it helps
Jun 26, 2012 | Iolo Technologies System Mechanic...
Error no. 302?
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
Dec 30, 2017 | Toshiba Satellite M45-S331 Notebook
Windows cannot connect to system event manager
If this problem has not existed for very long try doing a System Restore to a time prior to it starting.
Do you have more than one user profile on your system, if so, have you tried logging in with a different profile to see if the problem exists globaly or just in your normal profile? If the problem is with your profile only then this would suggest that the profile is corrupt and you should create a new profile if you don't have another already.
Another option is to run the System File Checker utility to determine if you have any corrupted or missing critical Windows files.
Lastly try temporarily disabling your AntiVirus and Firewall software then try to access the Event Viewer management console - it is probably best to have your computer disconnected from any internet access when doing this. If this succeeds then check for any events related to the error in opening the Event Viewer - you may find it easier to clear all the current events first then recreate the error and look at the logs again to identify the most current and relevant entries.
Dec 29, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have a excella stx check scanner which I connected to a machine running windows 7 32 bit, when running the demo program the first time everything works as it should, if I close the demo and reopen I can...
click start control panel in the top right hand corner type in event viewer press enter
a window will open with a local event viewer at the top of lists logs custom views windows logs applications and service logs and subscriptions select the local event viewer you should see your error in log summary right click on it select properties this might tell you what the problem is and allow you work through your way through it (note i have not had an issue with my windows 7 ) this is only a guide for your assistance not a cure !
you might have to select other logs to find the error
hope this helps you
Aug 18, 2011 | Magtek Excella STX Check Reader PN...
I am getting system error, on computer start up and showing as this application has requested the runtime to terminate it is an unusuall way.I am using windows 7 home premium.
Try looking at the errors listed in your Event viewer ( see this link) and report back with the code that's listed for the system error. (Look at the application events and system events, and report any errors exactly as listed. If you right click on the event code and choose properties you can get more info on the event online. At least I think that still works in 7)
Anyway, let me know what you find.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 01, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Konami Silent Hill 4 for Windows Logo
8,138 people viewed this question
Top Konami Video Game Consoles & Games Experts
mark gardner
mark gardner
donny ardalando
donny ardalando
Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
