Question about Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic LMC DZ2- Battery charge not staying for long. Its says battery low after clicking a few pictures. These are both for rechargeble and regular batteries. Is it a problem if media card is corrupt by any chance?
  • Obertelli
    Obertelli Sep 17, 2010
    I assume that you mean the DMC DZ2 as there's no such model as LMC DZ2, please confirm.
    Exactly which "regular batteries" are you using. There is only one correct proprietary rechargeable version and plenty of fakes which often have the wrong type of chemistry to work correctly.
SOURCE: hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Posted on Mar 30, 2008
dutchman05
  • 487 Answers
SOURCE: Panasonic Lumix DMC-TZI - broken battery tab and battery/card door
well there is no easy way. You will have to open the machine up when you have ordered the parts you needed. Not to hard but make sure you keep you eye on the sequence how you pull it apart.
Posted on Apr 24, 2008
SOURCE: Panasonic DMC-TZ1 Won't turn on
I have just had this problem - was about to take it to shop for a checkover when I held shutter button down and then turned on - viola - don't know if it was a fluke or what
Posted on Jul 30, 2008
xscrewdriver
  • 246 Answers
SOURCE: says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
Posted on May 19, 2009
virtualhost
  • 2185 Answers
SOURCE: Not reconize memory card.
Hello Maira,
Try doing a factory reset of the unit.
It could be that one of your modified settings caused this.
Posted on Aug 04, 2009
I have a 2001 Dyna Low Rider, ever since I put it on the battery tender it just clicks when I try to start it, what could be the problem?
A Battery Tender will not charge a battery. They will maintain a "Charged" battery. Typically, if you put it on a low battery it will stay low of charge. Try cleaning the battery terminals and charge the battery, then turn the Battery Tender on.
Oct 24, 2012 | 2001 Harley Davidson FXDL Dyna Low Rider
Netbook will only stay on for a few seconds
Take the battery out and see if it will boot up. be sure to insert the power plug.I suspect that your battery is not charging up and the level is so low that the machine stays on for just a few seconds and shuts down to conserve the battery to keep itfrom going flat. Your charging circuit may not be working correctly, allowing your battery to be fully charged or your battery may be defective and cannot be charged up.
Dec 27, 2010 | Sylvania G-Netbook
I Use a fully charged(more than 14 hrs charged) New Sanyo battery 2700 mAH Ni MH rechargeable on my Sony Cyber Shot DSC-W5 Digital camera, when the power is on the battery display shown fully...
may be batteries you brought are old try with normal ( not rechargeble ) batteries. it would not last long but you can take atleast 30 to 50 photos. if it works it means new batteries are faulty.this type of problem i never saw in camera.use SANYO harmolattice HR-3UQ batteries.
Jun 22, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
I can only take a few pictures on my camera before it either shuts itself off and/or won't turn on again. When I try to turn it on the red light flashes but the lens doesn't extend, and then the light...
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
Takes a few photos then dies even with new batteries
Remove the battery
Pls test with an alt. batt.
Contact KODAK:
Oct 20, 2009 | Kodak EasyShare C613 Digital Camera
Problem with my rechargeble battery with my Canon Powershot A540.
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Sep 09, 2009 | Canon PowerShot A540 Digital Camera
Samsung D760
You can try with a higher battery v. gr. mAh 2100
Aug 09, 2008 | Samsung Cameras
Kodak CX7430 can only take 10 pictures with a new battery
Always use the best batteries you can buy. Either rechargeable or Alkaline. Do not use the cheapest, just because they cost less.
There can also be problems with the camera. This camera, I believe is a 4mpxl digital camera. It has a few years on it (about 2004), and in those years some of the digital cameras did need a lot of power to operate correctly.
My guess is that you are using cheap batteries, not the best you can buy.
Feb 24, 2008 | Nikon COOLPIX L3 Digital Camera
Kodak easyshare C340 camera
Which batteries did you out in, they either need charging or are not the right ones
Mar 23, 2007 | Kodak EasyShare C340 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
96 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
