How to find my router IP addess - Computers & Internet
  • Chris Hingee
    Chris Hingee Sep 17, 2010
    Do you mean the configuration IP address of the router?
    Guru:
  • 382 Answers
>Open command prompt by typing CMD on the search bar on your START menu
>on the command prompt type "ipconfig"
>it will show you the ip address, default gateway etc etc...ü
>comments, suggestions, votes and ratings will be greatly appreciated. Enjoy!
Posted on Sep 17, 2010
  • 6,487 Answers
To find IP address of your router, you can do that by opening command prompt from the computer that is working with the router.
To open command prompt Click Start > Programs > Accessories > Command prompt , and once command prompt is open just type there IPCONFIG and hit enter and you will see there some information you just need to look for Default Gateway and that is your routers IP address.
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
How do i access my settings so i can secure my connection? i can notuse the addess provided 192.168.2.2, the box nor the router itself do not bring the pin so i can access it?
IPCONFIG command I would have a IP of 192.168.xx.xx or something depending on which Computers/Servers that is on the network. So if you get a IP in IPCONFIG of 192.168.2.? then try to access the Modem/Router with the IP address of 192.168.2.1 with your username and password. for access router web page http://kb.linksys.com/Linksys/ukp.aspx?vw=1&docid=3d655af76e21457fa8b71a0c3a2a0c9c_3676.xml&pid=80&respid=0&snid=3&dispid=0&cpage=search and Linksys Router Support for more help.
May 26, 2014 | LG SMC DRAFT 11N WIRELESS 4PORT GIGABIT...
Can get configuration addess to work
Connect your computer to your router.
It should automatically get an IP-address.
Click the Windows "Start" button (Windows 7).
Type 'cmd' into the search-box.
Press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway", or the IP-address of the "DHCP-server".
That is the IP-address that you want to type into your web-browser.
Mar 01, 2014 | D-Link Computers & Internet
My computer can't see the router.
you will have to set the ip addess for the computer to see the router and the router to see the computer
log into the router from your web browser
type 10.0.0.1
this should open the user interface
user name - admin
password 1234 or admin
go to add new user
also add new user password
write them both down
add your computers ip address to the router
save and test
if nothing then run your network and internet wizard to give you access
need more help let me know your operating system and model and make of your computer
Thanks Misterdj
Apr 25, 2010 | D-Link Xtreme N DIR-655 Wireless Router
No Internet access
make sure you can access the router configuration page
change you computer ip addess to match the ip address range of the router
ex if router is 192.168.1.1
set computer ip to 192.168.1.2
subnetmask 255.255.255.0
and set default gateway and dns server address to gataway address
geateway 192.168.1.1
dns server 192.168.1.1
try it most probably you need to make sure you have configured your adsl user name and password and other settings in you router since you have rested it
Apr 11, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Ip addess
if you are using an ethernet cable make sure its connected directly into your Modem and not a port in your PC
May 10, 2008 | Microsoft Xbox 360 Console
Wireless card not connecting ti internet
Check if your wireless router is configured properly. try to reset the router to the default sitting
Apr 15, 2008 | Computers & Internet
Problom
well....don't keep us in suspense...finish the rest of the story...c'mon....Don't do this to us!!!
Feb 12, 2008 | D-Link DI-704P Router
I can't get to http://192.168.0.30/
On your machine, go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router.
Whatever the Gateway IP is, you should put in the addess bar of your IE, to get to your router.
Hope that helps.
Jan 13, 2008 | D-Link DI-704P Router
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
