I have an air conditioner Appliance AAC 1100 A-PTC that wos working for two days and now its not cooling or heating:-( Both outer and inner parts of the machine seems to be running but it wont heat or cool the room. When i try to turn it on there is a red symbol that lights up on the display (defrosting) this light goes off every 5 minutes or so,then the machine starts to blow air (not heated or cooled) for aprox 20 seconds then the red light comes on again and this procedure starts over again. I have also tried to run the machine on forced cooling (auto cool button) but it doesnot make any differense. Please help me im desperate.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 39 Answers
Probably out on a limit or sensor
Posted on Apr 09, 2017
  • 124 Answers
SOURCE: Won't heat or cool
as a general rule you sound like you have a compressor that is mechnically locked up. in other words it can't free itself from a stationary position and begin pumping and moving the piston. this is caused by one of several things. first kill power ,and carefully, and methodically examine all wires and terminal connections. be sure all are clean , snug and not burnt off etc. even the ones attached to the compressor itself. the compressor wire cover comes gently off and is usually held in place by a spring clamp be sure to replace when your done checking. if all wires check good then go to step two. that is a check of the capacitors. the silver metal large capacitor is the run capacitor. it keeps the compressor power in the windings out of phase so it runs same way everytime. it has a rated value stamped on its side. it should check with a volt meter that checks capacitors at not less than 90 percent of its rating . a 60 needs to check no less than 54 microfareds. etc. some capacitors have a common input side and a dual output side. they are labeled on top where the wires goes to the condensor fan and the other goes to the compressor. the larger circuit ,common in, to herm out is for the compressor. if in doubt label all wires , make a diagram and remove it and take to an electric motor shop and let them test it. in addition to the run capacitor that keeps the compressor going, you may also have a start cap that is usually black plastic. they have a" Yes by gosh you will" start function and store up voltage and deliver a powerful boost on start up to make the compressor get going. it can be tested the same way. be sure to ground the capacitors before testing after power is turned off by shorting across the terminals to bleed off any stored voltage. , with a screwdriver blade. by the way if you look at the silver run capacitor and its swollen up or bloated looking then its bad. you'll know what i mean if you ever see one. looks like it has the mumps. they really puff up. top and bottom should be normally close to flat. if all that checks good then you must apply and amp probe to the black wire going to the compressor. when it tries to start observe the amp draw. if it is like 48 to 65 amps then the compressor is mechically locked up and probably needs replacing. if you don't have a plastic hard start capacitor and relay you can add one and it can many times break the compressor loose and you can get a few more years out of a compressor thats getting weak. try a T05 hard start kit or a KS1 hard start kit. to5 for up to three ton and a ks1 for 4 and 5 ton. simple to install .be sure the start relay is positoned correctly, instructions are on the package. good luck let me know outcome.
Posted on Nov 04, 2008
  • 30 Answers
SOURCE: whirlpool ACE244XS air conditioner blows out cool air when on hea
Due to Defective Thermostate Switch Try to Replace, will be ok
Posted on Feb 01, 2009
  • 3 Answers
SOURCE: Mitsubishi MSH 18NV no heating or cooling
You need an hvac tech to repair this unit. Good luck!
Posted on Feb 05, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 232 Answers
SOURCE: "cool on " heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Posted on Sep 20, 2009
My frigidaire Air Conditioner model Lra074at7 is not blowing cool air. Its very hot in the room I have it in. Not sure what to do??
Hello friend, thank you for your inquiry!
I understand that your Frigidaire air conditioner is not blowing cool air. There could be many possibilities to why your appliance is not cooling properly.
· Check to make sure the air vent is not in the open position.
· Make sure there is nothing blocking the airflow of the appliance.
· If your appliance is turned on in a hot room it could take additional time to remove "stored heat" from walls, ceilings, floors, and furniture.
Is your appliance under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this is helpful. -Matt
Aug 19, 2014 | Electrolux FRIGIDAIRE LRA074AT7 6500BTU...
My bakkie seems to over heat on hot days with the aircon on but when i switch aircon off she cools down. I have flusehd the radiator and the thermostat is working. It don't happen all the time only...
Check to see if you have an air conditioner fan which is usually fitted on the outer (grill) side of the radiator, make sure that works when you switch the air conditioner on when the temperature goes up.
Feb 18, 2011 | Mitsubishi Pickup Cars & Trucks
Compressor only stays on for 10 minutes then goes off. So it only cools for 10 minutes then it just blows hot air
Check coils for cleaning
Feel compressor for high heat
You may need a hardstart kit. Ask your nearest appliance parts man. Directions are usually on kit. Classified easy
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Aug 08, 2010 | GE APH10AA Air Conditioner
Not cooling
your ptc overload on your compressor has gone out and needs replacement,locate the compressor and unplug the overload off the compressor and take it to an appliance parts place and purchase the correct replacement ptc overload and plug it back in and your good to go
Jun 18, 2010 | Hotpoint HSS25GFP Side by Side...
Haier HWR10XC6 Air Conditioner - Where's the "Vent"
the vent can be used to provided some quantity of fresh air,which is located betwen inner blower and outer fan blade. the operating knob is provided in the front panel.
Jun 02, 2009 | Heating & Cooling
Carrier package HVAC unit with electric heat (10KW)
if you don't mind shopping over the internet here is a company I deal with on a daily bases Call Washer Specialties they have everything. 99% of the time.
Now if you have a appliance parts house in your area I would go there as this part you are talking about is a common part.
Feb 06, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
LWHD1200HR - LG 12000 BTU Heat / Cool Window Air Conditioner
i have a lg lwhd 1200hr window ac the heating system dont work . it blow cold air out not heat. can you help me
May 28, 2008 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
