Question about Sony Televison & Video
A DVD player cannot read any disc inserted in it otherwise it displays 'NO DVD'
  • Sony Master
  • 11,800 Answers
Clean the laser head - use a cleaning disk.
Posted on Sep 17, 2010
5 Suggested Answers
SOURCE: wont play discs
couls u help me
Posted on Dec 11, 2007
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
SOURCE: Sony DVD player reads no disc after inserting disc?
dvd player not spinning disc
Posted on Sep 24, 2010
jdvillanueva
  • 2098 Answers
SOURCE: when i insert a disc in my dvd player it reads "no
Hi mgarragh1,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I would advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 23, 2011
Bluray BD-6900 turns and is stuck on Load. No menu, nothing on screen, just the word LOAD displayed
Hello
Its laser pickup unit should be suspected. Just insert a lens cleaning disc and try to clean it. If it do not help you, the set need service
Mar 04, 2012 | Samsung BD-C6900 Blu-ray 3D Player
SONY DVP FX-930 unit 8 months old, tried DVD's, CD's insert disc and no matter what disc I install the unit displays "NO DISC".
Your pick up or lenz needs cleaning then your dvd player will be able to read your DVD. Please buy a good DVD cleaner.
Aug 13, 2010 | Sony DVP-FX930 Portable DVD Player
Can't Read Disc
Jul 06, 2010 | Philips DVP5990 DVD Player
Get display : NO DISC or BAD DISC
Probably the laser lens needs cleaning.
Purchase a laser lens cleaner disc at Radio Shack ($13). No chemicals are involved.
Read & follow the instructions. It cannot harm the player if not done right.
Sep 30, 2009 | GPX PDL705
After loading, disc error is displayed when dvd is inserted
hello i have had the same problem this maybe because of the region that your dvd is made to play.different dvd players play different.region dvd the regions should be on the dvd and the dvd cover.
Apr 25, 2009 | Televison & Video
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
Televison & Video Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
