Question about Refrigerators
I have a samsung fridge rs253baww the problem is the freezer working great but the fridge its not working at all its stays 76 sometimes it goes down to 69 or 67 but still not working inside its hot its not working at all but the freezer is below zero i did disconnect it for 24 hours then i did plug it back the same thing any idea guys what part is bad and were is the part located thanks
  • raffy melikian Sep 17, 2010
    my friend to take the panel off from inside the freezer or from the back outside
    and one more thing when i open the door of the fridge and push the light button after 5 second i can here the fan is on but no cold air or any air comes out from the ducts
    ok i took the cover off from inside the freezer there is no ice on the fan and the fan is working good there is a little ice on the aluminum radiator i think thats normal and on the top of the cover the 2 holes thats is going up no ice dry my friend what do u think
  • 17,130 Answers
The fault looks like the cold air flow is choked . Look behind the panel of the freezer, the duct to the fridge, there must be flow of cold air. If so remove the back panel of the freezer and check if the fan is working , if there is frost build up on the duct to the fridge. If so the auto defrost is not working. This is a timer located at the bottom rear of the fridge which will activate the heaters over a period of 8 hours cycle.
If there is no frost within as you mentioned it was put off for 24 hours, then it can be only the flow .
Trace from the flow area of the fridge to inspect for the block as there is nothing like a first view than to speculate.
Posted on Sep 17, 2010
  • Donald DCruz
    Donald DCruz Sep 17, 2010
    direction of the fan flow of air , Is it inthe right dirrection? You must get the cold air flow into the duct. Is the duct blocked? just check this out. You are doing good.
    Dont forget to rate this help.
I have a Samsung RS21DPSM American Fridge Freezer it has stopped making ice the water dispenser works fine but no water going into ice maker?
check the line that runs up the back of the fridge u have to take the back off sometimes there is something wrong w that line or there could be some water has frozen in the top of the line that goes into ur icemaker inside the freezer
Feb 28, 2015 | Samsung Refrigerators
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
Fridge off all night, how long for temp to go down from 76
will take a while at 76 also check fan in freezer section make sure not iced up and is working correctly the moisture from the warm air can cause the fan to ice up causing more problems
Nov 19, 2009 | Sub-Zero Refrigerators
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
