I cannot install windows to my computer it is saying hardisk not found pls help
  • 506 Answers
Go to the BIOS of your system, Configuration, Disk type set it to Compatibility mode and save and exit.
Then try to install your OS again.
Posted on Sep 17, 2010
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
In the midle of installation it say error c:\config.msi\19db53.rbf. i click retry and it go on to the end of installation i do the registration and succefull , when i start the autocad it open a grey...
two posibilities the cd installer might have scratches cause for not installing properly some files for windows are not installed..seconds your hardisk has a bad sector tyr to scan your disk and fix bad sector..reformat your computer and install again your OS
Aug 20, 2010 | Computers & Internet
My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy etc.press F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your computer.press F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Feb 21, 2010 | Dell Dimension 3100 PC Desktop
When i start my computer it says press f1 to
This means your hard drive has either failed or is disconnected.
Given the age of the computer it's most likely the drive has failed.
Let me know if there is important data saved on the computer. Otherwise, replace the drive and re-install windows and it should work again.
Crankstart
Jan 08, 2010 | Dell OptiPlex GX150 PC Desktop
I cannot install software
Hi..
This happen due to 3 reasons,
The Hard drive is bad.
The BIOS Setting have to be put to SATA.
During the the installation the have to press the F6 option to install the SATA drive drivers.
Let me know
Thanks
Smith
Aug 09, 2009 | ASUS P5LD2-VM Motherboard
My computer freez and go blank after formatting the computer
Greetings,
There is no problem with your computer as a whole it is your hardisk that has a problem, It cannot continue installing the system files because an error occur in your hardisk. Format your hardisk with other computer.
If you have an extra hardisk much better.
Thanks
Nov 12, 2008 | IBM NetVista PC Desktop
Instaling windows xp
when you removed vista then you install Xp your Hardware drivers are not match so you need to install porper harware drivers..
Jul 03, 2008 | Toshiba Computers & Internet
Want to erase drive
If your Laptop is purchased with Recovery Disk, you can use that disk to restore the default setting of your laptop. It usually FORMAT your hardisk and erase all programs and files saved on your Hardisk. If Recovery Disk is not available then you can simply use your provided Windows Installer to format your Laptop and install a Fresh Windows on your Laptop, be sure to format the Whole Disk Drive to erase the files.
Jun 11, 2008 | Dell Inspiron™ E1505 PC Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
