Question about AOC 19LVWK LCD Monitor
Usb port and speaker ports not working - AOC 19LVWK LCD Monitor
    Guru:
  • 382 Answers
Download the drivers for your Chipsets on your computer manufacturer's website...
Posted on Sep 17, 2010
My laptop is suddenly not recognising my iluv usb connected speakers.Is there a fix?
To start, try connecting the speakers to a USB port on a second computer. That will help you find out if the problem is with the speakers or the computer.
If the speakers work on the 2nd computer, try connecting a different device to the same USB port on the computer. Also try a different USB port on the same computer.
Feb 27, 2015 | Computers & Internet
Bad Speaker Port
I would head to a radio shack and get a replacement port and make the repair.
Jun 19, 2013 | Audio Players & Recorders
The speakers quit working/what do I do?
Make sure that it is the speakers that stopped working by unplugging them from your computer (or whatever you have them plugged into), and plugging headphones into the same jack that the speakers were plugged into.If the headphones work, you have confirmed that the problem is with the speakers. If the speakers use an AC adapter (black plastic cubical thing that plugs into the wall), then you might try getting a replacement AC adapter with the same output (AC or DC), voltage, polarity (which side is positive, and which is negative), and connector. If the speakers plugged into a USB port for power, your USB port may have turned itself off. In that case, reboot the computer to see if the USB port will turn back on.
If none of this works, you have to buy new speakers.
Apr 18, 2011 | HP JBL Platinum Computer Speakers
I have a Logitech Z-5 Speakers which connect to my laptop by usb. the light doesn't come on on the speaker.. looks like the usb wire isn't working or a fuse has blown due to a power outage. what do you...
Did you try using a different USB port.
If there is any short of the cable then on PC there should be a massage like "Power Surge of USB port", if you don't receive this massage then probably something wrong inside the speaker.
Mar 12, 2011 | Computers & Internet
My usb powered speakers light up but my system still shows no audio device present
Hi, well windows must install the correct Drivers before your device will work. You need to check this.
As the speakers are powered by the USB port and require 5 volts to operate. Some USB ports do not have a full 5 volts DC and have current limiting. Your speakers may require more power then your USB ports can give. or try them with a Powered Hub.
Have you tried them in another computer? to see if they actually work?
Try, another USB port, try a powered hub.
Ensure that they show up in device manager, if there right click, and select upgrade Drivers, allow it to look for and install the generic driver.
make sure it is set as your Default device.
You may have to disable your onboard sound from the BIOS, first too.
Aug 29, 2010 | Durabrand Audio Players & Recorders
Hi, I have a usb speaker but not working. What sho...
chnage the usb port and connect to another port.
Have a nice day and do not forget to rate please...!
May 18, 2010 | Computers & Internet
USB port problems
You need the motherboard specs, which you can look up on the internet, based on the maker.
With the USB ports, the front ones often don't include power.
So plug a powered 4 port hub into the front port, and then the hub will supply the power after that.
Jun 26, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
USB ports do not work. No sound from Speakers
Hi I am Vortash ... .. if you have your audio drivers re-install them after you Check the sound settings in advanced and make sure the speakers are not disabled .. As for the usb ports check in device manager that the usb is installed and enabled and that your drivers are working if not update if it asks search web say yes if your on the web where you are and get the latest ones ... hope this helps Vortash
May 02, 2009 | Dell Inspiron 1100 Notebook
They just stopped working!
is your computer old? Are The Speakers old? Is Your USB Not Dusty? ( if is, blow on USB Port )
Dec 15, 2007 | Benwin SP691 2-Pc USB Powered Speakers...
AOC 19LVWK LCD Monitor Logo
202 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
