Question about Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital... E18 Problem
Camera lense will not retract when shut off. Not able to take any pictures, but can view pix from card. Replaced batteries and tried hooking camera to view pix on TV but still not able to use....has E18 error code on screen.
  • Anonymous Jul 21, 2008
    E18
  • Anonymous May 06, 2009
    e18 error started 12 months after i bought camera - i think i was always been careful. Got progressively more frequent till it stopped working at all
#4 worked first try!
Posted on Aug 06, 2008
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 18, 2008
My solution rather than using a piece of tissue to clean around the lens housing is to do it with a damp toothbrush, this gets in deeper and cleans it better :)
Posted on May 13, 2012
  • asiagold
    asiagold May 13, 2012
The Lens was stuck in the "on" position on my camera. Tried #4 and IT WORKED!!! Thanks!!!!
Posted on Jul 19, 2008
Len will not go in and e18 code is on the pic
Posted on Mar 09, 2010
Helppppppp!
Posted on Oct 05, 2008
Canon S2 Is
The button you press to focus and snap picture does not work at all. At first I was having a problem with it not wanting to focus. Now I can't take a picture at all.
Is this a matter of replacing one thing or more? Is this something worth fixing? Should I just get a new camera? I am just not sure what to do.
Thanks for your help.
Barb
Posted on Jul 03, 2008
E18 lens will not retract
hi your answer of your problem e18 lens will not retract.
i have send this information to solve your problem.
Turned the camera on with weak batteries. Lens extended and won't retract.
Feb 15, 2010 | Canon PowerShot S2 IS Digital Camera
Won't shut off or take pics. code E18 comes on
Try removing the batteries and cleaning the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Also you'll want to clean the battery and charger the same way. Thank you, Dana
Feb 02, 2010 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS camera showing code E18
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jan 20, 2010 | Canon PowerShot S2 IS Digital Camera
Canon Powershot S2 Is
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 11, 2010 | Canon PowerShot S2 IS Digital Camera
My lens of my canon powershot s21s camera would not contract and I cannot take pictures. When I try to use it I get a code saying E18 and a beeping sound.
I have had several digital cameras that when the lens is extended and the camera is dropped or the lens is bumped, the lens itself will become "off track" and will not retract or work without have the whole camera taken apart
Sep 22, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 is lens won't retract error e18
Try tapping not so gently. other than that it will most likely need to be taken apart and put back together the right way. And any broken parts replaced.
Mar 17, 2009 | Canon PowerShot S2 IS Digital Camera
When I try to zoom, screen goes black and "E18" appears in bottom corner
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Oct 31, 2008 | Canon PowerShot S2 IS Digital Camera
Help
sir E18 err, related to lens i think ur camera droped u try ur local repairer this is repairable
Mar 25, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
2,902 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
