I have been able to connect my DVD recorder to my Samsung LCD Tv and can reord from the channels I get on this Tv.,. I have a TelstraClear Cable TV box with which I receive Sky Tv channels in digital format. I cannot see these using the DVD recorder. I have a digital coaxial TV output port on the cable bx but have not got a cable to connect to the DVD recorder which only appear to have an RC in port. Can you tell me how I can record from my cable box instead of or as well as the TV?
  • 11,800 Answers
You need to connect the dvd recorder directly to the cable box:At the back of the box you can see that there are different possible connectors. Use the HDMI to send the signal to the tv and the Composite and audio connectors (yellow , red and white) to the recorder. At the back of the recorder you will see that there are several separate sets of inputs - plug in the cable from the box in one of them.
This way you will have 2 signal sources and 2 cables there - one from the tv and the other from the box. You will be able to record from both - just select from the menu from which.
Posted on Sep 17, 2010
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Can't record from tv
u have a cable/sateliite connection...cable from wall to cable box in...cable box out to vcr/dvd in....vcr/dvd out to samsung lcd in....(vcd/dvd and samsung must be tune to ch 3) now u should be able to record all channel (note HBO, and some others like it may not allow dvd recording) vhs yes.
if this helpful feel free to rate
Jun 16, 2009 | Sylvania DV220SL8 DVD Player/VCR
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Samsung series 6 LCD no video output!
Try connecting your DVD recorder directly to the source (satellite/cable box) and then to the TV.
Feb 25, 2009 | Samsung TXN3245FP 32" TV
How to record a running program from TV to DVD
RUN ANT,CABLE INTO DVD RECORDER THEN RUN A CABLE IN TO THE TV FROM THE OUTPUT OF THE DVD RECORDER YOU MUST HAVE TV ON CHANNEL THREE TO WATCH AND RECORD AT SAME TIME ,SET CHANNEL TO 3 ON DVD RECORDER OR INPUT SELECT CHANNEL YOU WANT TO RECORD AND PUSH RECORD WHEN READY
Dec 07, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
How do I record tv programmes
from the specs I have read online you cannot record with that dvd unit in this sound system it's just a player that plays a lot of different formats like dvd-r/w dvd+r/rw. so to record you need to get a dvr from your cable or sat company or get a seperate dvd recorder.
Oct 29, 2008 | Samsung HT-DS100 System
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
