Question about Refrigerators
We have a freezer that runs on R404. The system has had a leak, we have repaired the leak pressure tested and evacuatted system Can we charge with R134a
  • Refrigerators Master
  • 43,501 Answers
No, the R-$)$ has different cooling properties then R-134A...
You cannot replace one with the other...
You will need to get R-404 to recharge the system...
heatman101
Posted on Sep 18, 2010
Rf 266 is leaking gas.
Thats a very big leak. open freezer do u smell it? Look mat the lines any of them oily thats a good indication of the leak.Pump down , repair leak , pressure test an vacuum then a charge an your good.
Nov 11, 2014 | Samsung RF266AE (260 cu ft) Refrigerator
Air conditioner stops working
The most likely cause if this problem is that the system has a leak and is low on charge, have an AC repair shop run a pressure test on the system to see if the pressures are low which would indicate a leak is present. Repair the leak before you recharge the system
Sep 05, 2012 | 2001 Mazda Protege
What to do if you have a freon leak in the freezer
charge with detail (that is a Freon with Red dy solution to help locate your system leak) locate leak, repair using silver solder, evacuate system completely, pull vacuum down to 27" plus Lbs. vacuum, close system to hold vac pressure, monitor pressure for 30 minute or so, if vacuum hold pressure then you have successfully fixed your system leak, next hook up your system to the manifold gages assembly to a Freon supply source, all this while retainning your vacuum pressure, slowly crack open the valve on the manifold to allow the new freon to enter your system until you see pressure building up in you system, next monitor the discharge line i.e. the bigger line until you see frost extending outside of your freezer unit toward your compressor assembly, then close the freon supply valve, wait for a while to see if the frost line recede into the unit box, if it does not recede but stay out of the box or extend some more then you must must release some freon slowly a very small amount at the time until the frost line has regressed into your freezer box. this should complete your repair, good luck
Apr 24, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
HOW DO YOU CHARGE R404 A SYSTEMS REFRIGERATION
First question, why do you need to charge the system? Second is it a remote unit or self contained. Third do you have a set of refrigeration gauges? The best wau is to weigh the proper charge into the machine through the gauges. That varies depending if you are air cooled, water cooled or remote.
Sep 23, 2010 | Hoshizaki Freezer Commercial Ice Machines...
FUM21D upright freezer, NOT frost free. Top shelf coil cooling, others are not. Sides are not as warm as usual. Running constantly. Coolant leak? Why top shelf cooling?
I note this is in fact not a frost free freezer and that there is not an evaporator OR a condensor fan. If it is running constantly and the cooling coils are clear as in not covered in lint then the most likely cause is a low coolant level. A low coolant level will allow partial but not total system cooling. The only way to know for sure is to have the systems pressures tested. At that point who ever checks the coolant pressure will have to determine why the coolant leaked out, repair the leak and then re-service the system with coolant.
Any parts required can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5209535&diagram_id=24630225#d24630225
Thanks for choosing FixYa.
Kelly
Sep 10, 2010 | GE 20.6 cu. ft. / 583 liter Upright...
Ice on top of compressor
You may have a slow refrigerant leak or too much refrigerant in the system. Contact an appliance service company.
Feb 26, 2010 | Delfield 032-F2FH ColdPro Solid Door Reach...
Commercial refrigeration motor over heating and low suction press
Add 404A to system. It is low on gas. But kep an eye on the TXV for ice buildup. Make sure unit is free of ice before you charge it. It is difficultr to charge a refer system when itis iced up. Rus
Dec 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
What should refrigerant gauges read when charging walk in freezer?
Depends on what kind of refrigerant its works, if is an old unit probably is charged with R12 or R22 newer ones work with R404 ;for R12 presures should be around 20psi on the low side and 160 on the high side ,for R22 about 60 and 250 and for R404 50 and 350 ;you have to look at the condensing unit tag to find out what type of freon its uses ,or look at the expansion valve at the evaporator coil.
Jul 31, 2009 | Everest Refrigeration Freezers
No pressure on suction side of condenser
sounds like system is very low on refrigerant charge,let it run and see if it goes into a vaccum.if you had a problem in the coil your liquid line will have higher pressure.
Mar 25, 2009 | Ruud Central System Air Conditioner
Master built 2 door freezer model BLG-48HD serial 016254 still in warry. How do you tell how long defrost and time it goes into defrost? Also box won't pull down to temp, high alarm goes off. temp 25 in...
most units are on a timed defrost that occurs at different times so finding the exact time will be hard but defrost times are about 30 minutes. from the pressures you posted I'm thinking that the condenser fan is not running or the condenser itself is plugged up with dust. (i'm not very familiar with r404 but for most other refrigerants the hi side pressure is really hi). if its still in warranty you would be better off to call your service company after your sure the condenser itself is clean to prevent a charge for impproper maintanence. thanks peyton
Mar 06, 2009 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
