I have a vasco axs guard gatekeeper (version 7.6.2. pl006) with ipsec tunnel (psk) between a dlink dfl-800. On the vasco there is another tunnel (e-tunnel - psk) to another site to a vasco (version 7.6.0). My problem is that weekly 3 to 4 times the tunnels are lost connection. Then a have to restart the vasco with the 2 tunnels configured (7.6.2) and the problems are solved. I realy don't know what the problem is, plse any assistent would be very very great. Thanks in advance! Regards, Wilfried Vanheuckelom
4 Suggested Answers
  • 196 Answers
SOURCE: Configuring IPSec between a Microsoft Windows 2000 or XP PC and a Linksys VPN Router
Windows XP or Windows 2000 IP Address: 140.111.1.2 ? User ISP provide IP Address, this is only a sample Subnet Mask: 255.255.255.0 BEFVP41 WAN IP Address: 140.111.1.1 ? User ISP provide IP Address, this is only a sample Subnet Mask: 255.255.255.0 LAN IP Address: 192.168.1.1 Subnet Mask: 255.255.255.0 Step-by-Step [Windows 2000/XP] Create IPSec Policy 1. Click the Start button, select Run, and type secpol.msc. in the open field. 2. Right-click IP Security Policies on Local Computer and click Create IP Security Policy. 3. Click the Next button, and then type a name for your policy (for example, ?to_befvp41?). Then, click Next. 4. Deselect the Activate the default response rule check box and then click the Next button. 5. Click the Finish button, making sure the Edit check box is checked. Build 2 Filter Lists: ?WinXP? BEFVP41? and ?BEFVP41? WinXP?. Note: The references in this section to ?WinXP? can easily be exchanged for ?Win2000?, if running Windows 2000. Filter List 1: WinXP? BEFVP41 1. In the new policy properties, deselect the Use Add Wizard check box and then click the Add button to create a new rule. 2. From the IP Filter List tab, click the Add button. 3. Type an appropriate name ?WinXP? BEFVP41? for the filter list, deselect the Use Add Wizard check box, and click the Add button. 4. In the Source address field, select My IP Address. 5. In the Destination address field, select A specific IP Subnet, and fill in the IP Address 192.168.1.0 and Subnet mask 255.255.255.0. 6. If you want to type a description for your filter, click the Description tab. 7. Click the OK button. Then click the OK (for WinXP) or Close (for WIN2000) button on the IP Filter List window. Filter List 2: BEFVP41? WinXP 8. On the IP Filter List tab, click the Add button. 9. Type an appropriate name ?BEFVP41? WinXP? for the filter list, deselect the Use Add Wizard check box, and click the Add button. 10. In the Source address field, select A specific IP Subnet, and fill in the IP Address 192.168.1.0 and Subnet mask 255.255.255.0. 11. In the Destination address field, select My IP Address. 12. If you want to type a description for your filter, click the Description tab. 13. Click the OK button and click the OK (for WinXP) or Close (for Win2000) button on IP Filter List window. Configure Individual Rule of 2 Tunnels Tunnel 1: WinXP? BEFVP41 1. From the IP Filter List tab, click the filter list WinXP? BEFVP41. 2. From the Filter Action tab, click the filter action ?Require Security?, and click the Edit button. 3. verify that the Negotiate security option is enabled, and deselect the Accept unsecured communication, but always respond using IPSec check box. 4. Select the Session key perfect forward secrecy (PFS) and remember to check the PFS option on the BEFVP41, and click the OK button. 5. From the Authentication Methods tab, click the Edit button. 6. Change the authentication method to Use this string (preshared key), enter the string ?XYZ12345?, and click the OK button. This new Preshared key will be displayed. Click the OK button to continue. 7. From the Tunnel Setting tab, click The tunnel endpoint is specified by this IP Address radio button and type the WAN IP Address 140.111.1.1 of the BEFVP41. 8. From the Connection Type tab, Select All network connections and click the OK button to finish this rule. Tunnel 2: BEFVP41? WinXP 9. In the new policy properties, deselect the Use Add Wizard check box and click the Add button to create the second IP Filter. 10. From the IP Filter List tab, click the filter list BEFVP41? WinXP. 11. From the Filter Action tab, select the filter action Require Security. 12. From the Authentication Methods tab, click the Edit button. 13. Change the authentication method to Use this string (preshared key), enter the string ?XYZ12345?, and then click the OK button. This new Preshared key will be displayed. Click the OK button to continue. 14. From the Tunnel Setting tab, click the radio button for The tunnel endpoint is specified by this IP Address and type the Windows 2000/XP IP Address 140.111.1.2. 15. From the Connection Type tab, select All network connections. Then, click the OK (for WInXP) or Close (for Win2000) button to finish . 16. From the Rules tab, click the OK button to go back to the secpol screen. Assign New IPSec Policy 1. In the IP Security Policies on Local Computer MMC snap-in, right-click the policy named to_befvp41, and click Assign. A green arrow appears in the folder icon. [BEFVP41] Setup Screen 1. Open your web browser and enter 192.168.1.1 in the Address field and press the Enter key. 2. When the User name and Password field appears, skip the user name and enter the default password admin and press the
Posted on Feb 16, 2006
SOURCE: D-Link DI-808HV Router VPN Tunnel No Package Flow
04810481
Posted on Oct 09, 2008
  • 6 Answers
SOURCE: I have tried to connect
First thing to try is making sure you have the latest firmware on the router. If you have not logged into it before you need to type http://192.168.2.1 in your browser address bar and log in when prompted. The router by default does not have a password set so it might be worth setting one in system settings. You should find on the menu an option to update the firmware. Read the screen should guide you how do this. If the firmware is up-to-date and you still have a problem try disabling your firewall on the pc to see if it's getting in the way. Don't leave the firewall off if you find it's causing the problem you just have to work out how to configure it to allow the traffic out. The route should allow this traffic out by default.
Posted on Dec 02, 2010
What command do i run to show IpSec tunnel status on ASA 5520
show ipsec stats
this command was introduced in code 7.0
it will show the active tunnels, the previous tunnels and several other stats of inbound and outbound packets.....
for example:- IPsec Global Statistics ----------------------- Active tunnels: 2 Previous tunnels: 9 Inbound Bytes: 4933013 Decompressed bytes: 4933013 Packets: 80348 Dropped packets: 0 Replay failures: 0 Authentications: 80348 Authentication failures: 0 Decryptions: 80348 Decryption failures: 0 Decapsulated fragments needing reassembly: 0 Outbound Bytes: 4441740 Uncompressed bytes: 4441740 Packets: 74029 Dropped packets: 0 Authentications: 74029 Authentication failures: 0 Encryptions: 74029 Encryption failures: 0 Fragmentation successes: 3 Pre-fragmentation successes:2 Post-fragmentation successes: 1 Fragmentation failures: 2 Pre-fragmentation failures:1 Post-fragmentation failures: 1 Fragments created: 10 PMTUs sent: 1 PMTUs recvd: 2 Protocol failures: 0 Missing SA failures: 0 System capacity failures: 0
Dec 11, 2010 | Cisco ASA 5520 Firewall
Cisco VPN doesnt get connected through DI-524UP router. Worked fine until recently for both the laptops we use. Log indicates Receive: Purging stale cached fragment(s). Direct connected on the Motorola...
Cisco VPN
Upgrade your router to the latest firmware. You can download firmware at http://www.dlink.com.au/tech/ .
Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Configuring PC running VPN Client Software:
Step 1 Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Step 2 Change IP Address to be outside of the routers DHCP Pool (i.e. 192.168.0.99). By default the DHCP pool is 192.168.0.100 - 192.168.0.199.
Step 3 Configure Cisco VPN Client - Connection Properties.
Step 4 Check Enable Transparent Tunneling.
Step 5 Allow IPSec over UDP ( NAT/PAT).
Configuring Router using the Web-based configuration:
Step 1 Open the Web Configuration Page by entering 192.168.0.1 into your web browser. Enter username (admin) and your password (blank by default).
Step 2 Check the Status tab and make sure that you are running the latest version of firmware. If not, upgrade firmware before proceeding.
Step 3 Click on the Miscellaneous button on the Tools tab. Enable both PPTP and IPSec.
Step 4 Click Apply.
Step 5 Click on the Virtual Servers button on the Advanced tab.
Step 6 Enable IPSec from the list and configure as follows:
Private IP: IP Address of the PC running Cisco VPN Client
Protocol: UDP
Private Port: 500
Public Port: 500
Schedule: Always.
Step 7 Click Apply and then Continue.
Step 8 Enable PPTP from the list and configure as follows:
Protocol: TCP
Private Port: 1723
Public Port: 1723
Schedule: Always.
Step 9 Click Apply and then Continue.
http://www.dlink.com.au/tech/default.asp?model=DI-524UP
Nov 16, 2009 | D-Link AirPlusG DI-524UP Wireless Router
Unable to reset Dlink DFL 700 network firewall
To perform a factory reset using the reset button do the following:
Step 1: Make sure that the DFL-200/DFL-700 is on.
Step 2: Press and hold the button located on the back of the DFL-200/DFL-700 below the word Reset using a paper clip for 10 seconds.
Step 3: Release the button.
Oct 23, 2009 | D-Link NetDefend DFL-700 Firewall
How to configure
http://www.dlink.com/products/?pid=DFL-800
Oct 07, 2009 | D-Link DFL-800 Firewall
Vpn site to site
you need to create an IPSec tunnel between the router and windows server 2003 (run secpol.msc). From the dlink router, you need to set the IP address of the VoIP gateway as part of the LAN that is included on the VPN tunnel. Since it is the server 2003 that has a static IP, you need to initiate the connection from the Dlink router.
Jun 23, 2009 | D-Link Express EtherNetwork DI-LB604...
VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Mar 02, 2009 | D-Link (DIR-130) Router
Faulty DFL-700 image - missing FWCore.cfg
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
Download Link:
http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
May 05, 2008 | D-Link NetDefend DFL-700 Firewall
My firewall DLINK 800 drops my connection ADSL perioducly
it sounds like you don't have it set up with the Keep Alive setting
Apr 11, 2007 | D-Link DFL-800 (DFL800) Firewall
NAT Traversal
NAT traversal refers to the common problem in TCP/IP networking of establishing connections between hosts in private TCP/IP networks which use NAT devices Client-based IPsec VPN connections often do not work when passing through a NAT device as the IKE and IPsec protocols were not designed to work through NAT. NAT Traversal is an add-on to the IKE and IPsec protocols that allows them to work when being NATed. NAT traversal is only used if both endpoints support it. D-Link products that currently support NAT traversal include the DFL-200, DFL-700 and DFL-1100. Note: The DFL-80 and DFL-300 do not support NAT traversal.
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
