Question about Klein Electronics Netrome Security Black Box 8Channel 4Cam Surveillance System
Dss-x8 system audio and mic connections settings on moterboard
I'd like to use my canton DSS 303 as a computer speaker and i don't know whether i can or how
It doesn't know or care what feeds it if the interface is compatible.
http://hifi-ring.com/2008/03/30/canton_dss-303_digital_sound_station_for_ipod.html
" ...via the 3.5mm line-in connection". Find a stereo cable that matches whatever you have on the PC end and 3.5 mm on the DSS.
Sep 09, 2011 | Canton DSS 303 Mutimedia Series Audio...
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
I cannot get sound from my sony tv (ldl 40bx420) to play through my strdh520 .....my blue ray sony bdp s580 sends a nice signal through it to the speakers.....I have tried every tip in the manual to try to...
Depends on your sources and connections. If you have Cable Box, DSS, FIOS, etc. Audio would be from Coaxial or Digital Optical from the respective source. You would need to check the Audio settings on the Cable Box, DSS, etc. If you are using Cable or off-air, direct from the TV, it would be connected from the analog audio (rca) or Digital Optical output from the TV and The Audio out setting on the TV should be set to Fixed. On the Sony Receiver, make sure all inputs in settings menu for audio are set to auto. Hope this helps, if you still have a problem, post a reply/comment with any other equipment you have connected between TV & Receiver
Jun 27, 2011 | Sony STRDH520
How do i install sound on a longitech webcam?
The webcam mic uses your computer sound system all you can do is to configure your mic to the program you wish to chat in.
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Jan 23, 2010 | Logitech 961462-0403 Webcam
C200 does it have a mic?
Yes it has a mic check your audio set up.
Laptop x webcam/mic x Vista x Yahoo Messenger
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
Restart computer
Jan 02, 2010 | Logitech Webcam
How do u turn the mic. on ?
Set up Audio
If you have an older OS than Vista you may have to access your hardware from the Contol Panel
I have used Yahoo Messenger as an example if you intend to use your mic in WLM or Skype, its a lot easier find 'Tools' and then 'Audio set up'
TEST SPEAKERS
Set required mic as default - click on mic font to highlight and click "Properties"
Restart computer
Oct 10, 2009 | Microsoft LifeCam VX-6000 Webcam
Person on other side cannot hear me
please check the microphone setting under audio setting under control panel ...
Oct 09, 2009 | Yahoo Messenger
WHERE CAN I FIND A CABLE THAT CONNECTS SUBWOOFER TO TUNER MODEL NO. CD-X8 TEAC
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Teac CD-X8 CD Shelf System
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Audio converter for dss audio files
You can convert DSS file into wav format with DSS Player 2000 or the latest version. it can only convert it into wav format. after convert into wav format then u can use any other converter to change it into any other audio format. u can use total video converter or Sonic record now multilanguage software.....
best of luck.....
Feb 08, 2008 | Olympus WS-100 Digital Voice Recorder
Klein Electronics Netrome Security Black Box 8Channel 4Cam Surveillance System Logo
323 people viewed this question
Top Klein Electronics Home Security Experts
Lawrence Oravetz
Are you a Klein Electronics Home Security Expert? Answer questions, earn points and help others
