Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Can you change an Intex - chlorine above swimming pool to a saltwater?
    Novelist:
  • 116 Answers
Sure no problem. Just make sure salt level and other chemistry (PH, ALK, Hardness) is within normal ranges. There are number of Salt system available these days, some designed specifically for above ground. Your best bet is to visit a local pool retailer, and ask them for their recommendations based on your pool size type, and type of equipment
Posted on Sep 20, 2010
How do you shock a saltwater system above ground pool
shock with chlorine until chlorine shows as free then let chlorinator take over or use non chlorine shock but that will lower your PH keep and eye on it
Nov 05, 2013 | Intex Automatic Salt Water System for ...
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Can you swim in pool went boost is on?????
Our family does and have not had any issues.. Our choice!.BUT!!!!!! If the chlorine level is above 3 PPM, we wait a day until the level drops.. Important!!! Intex manual does state the following warning..
Aug 08, 2011 | Intex Automatic Salt Water System for ...
Hello I have a 15x48 intex above ground Easy Set pool and saltwater system. All was working well for about a week and a half. I couldn't get my ph and TA levels right so I brought a sample to my...
I've been running mine for 2 years without checking anything other than the free chlorine level and it's always crystal clear without adding NO CHEMICALS. Make sure you have the correct salt level and start the unit. Take a water sample at the discharge after the chlorinating light comes on and check to see if it measures chlorine. Should be slightly yellow color. If so, your unit is producing free chlorine.
Jul 13, 2011 | Intex Automatic Salt Water System for ...
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
Hi, I have let my intex above ground pool go green over winter and with summer approaching don't know if I need to add extra salt or something else to get the pool ready for swimming. It is a 14 foot,...
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
Oct 25, 2010 | Intex Automatic Salt Water System for ...
Can chlorine be added to the saltwater intex system if salt has already been added
it can be added and also regular house hold bleach
why would you need more chlorine?
If you are needing more then something is wrong
If your salt content is not 3000ppm or more but not above 3800ppm then you are not going to be able to generate enough chlorine
Also you should be using a stabilizer that help hold chlorine content
Jun 19, 2010 | Intex Automatic Salt Water System for ...
How much salt do you add to a 18 x 48 pool
what is the average depth... your going to take your widthxlengthxaverage depth and then multiply by 7.48... thats how many gallons your pool makes up.... most salt chlorinators call for 2700 to 3700 ppm ... get yourself a salt test kit, and make sure you use salt made for swimming pools....
May 24, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
134 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
