The hot wash cycle has stopped working... it starts on the cycle as normal and then stops when it gets to the C (95 degree) cycle. I also am not sure if on the other cycles it is heating the water as the drum does not feel warm.
Thanks for your help.
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
If the unit is fed by both hot and cold it is possible that the single hot valve or one side of the double cold valve is not operating. Maybe a silly question but could one of the taps have been turned off inadvertently?
The other possibilty is that the pump filter or outlet hoses are blocked and the machine cannot empty the detergent water ready to refill with clean rinse water. To test the cold valve put the w/m on a cold wash cycle, open the drawer and check the water flow. To test the other part of the same valve, put the w/m on the rinse cycle that would take the softener or a wash cycle with prewash. Test hot valve by selecting the hottest cycle usually 90 or 95 degrees, check water flow thru drawer. Hope this helps.
Hi there
i'm not sure if the fisher and paykel machines are any different in new zealand compared to where you live, but the only thing i can think of if it isn't displaying a fault code is if this machine is fitted with a reed switch(these make sure the machine stops if the lid is opened during operation) this may be faulty and staying open causing the machine to stop when the lid is closed. Hope this helps.
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Growing up in Europe with front loader washing machines I thought I only had to hook the machine up to the cold water tap and it would heat the water up to the required temperature. However, this model needs to be hooked up to both the hot and the cold water tap in order to function properly. Everything is working fine now that I have done that.
