Question about Sony ES7 LCD Projector
I own a vpl w5 sony projector i replaced the lamp and still shows no picture. it projects white lines and vertical black lines. white background . can you please help me find out the problem. tanx jp
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
  • 4234 Answers
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Picture not projecting from RGB input A of my Sony projector Model Number VPL-EX5. What could be the problem
First...Check that all cables are connected correctly..If they are then look at the condition of the cables you're using to see that they are not damaged..Second..Your projector has a lamp that may need to be replaced because even though your unit may not show you a picture then seeing the light will eliminate having to replace the bulb
Nov 05, 2016 | Sony Office Equipment & Supplies
How do you reset the lamp timer for a sony Bravia
Turn on the projector
press MENU (as show in picture step by step)
use down arrow key and select SETUP
press ENTER
use down arrow key to select LAMP SETTING
press ENTER
menu screen below will be appeared.
ON SCREEN display
setting for lamp replacement
Has the projection lamp been replaced?
YES NO
Select YES with left arrow key (yes is preselected)
press ENTER
ON SCREEN display
lamp replacement process is now complete
press ENTER
now exit the MENU with menu key and check the lamp timer
Feb 09, 2011 | Sony BRAVIA VPL-AW15 LCD Projector
I want to connect my Sony projector to a Humax freesat box - I am only getting a black & white picture - how do I get a colour picture
may be the Sony Projector performs the black and white functions only,So kindly get a coloured projector
Jun 20, 2010 | Sony VPL-CX75 Multimedia Projector
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
VPL ES 1 LAMP RESET
i have replace lamp but stlii no picture coming through
Sep 23, 2008 | Sony VPL-ES1 Multimedia Projector
Bleeding blue color upon projection
Yes you can replace the lamp, but service in must including the RGB Panels for the same. that will solve ur problem.
Viren
Nov 24, 2007 | Sony VPL CS1 Multimedia Projector
Projector turns off after 30 seconds.
I had the same problem I replaced the motor/lense cover unit at the cost of $AU140.00 and that fixed it.
Leckie
Oct 09, 2006 | Sony VPL CX5 Multimedia Projector
Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
Aug 31, 2006 | Sony VPL-ES2 Multimedia Projector
Sony ES7 LCD Projector Logo
53 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
