Question about HP Compaq nx5000 Notebook
The little green light comes on ... computer makes a starting sound but does not start! A couple to times the computer did start up but then shut down by itself. At times the back elec. cable needs to be pushed in and moved around for the machine to start up!
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
LG shut off by itsself last night Comes on but, green light flashes a couple of times, makes a clicking sound red light comes on then shuts off. The tv also, turns on if i manually press the channel button...
Tries unplug,replug the tv back like an hour later.The tv,now it will resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Try website Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | LG 50PC5DC 50 in. Plasma HDTV
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Doesn't always start, dies as I'm driving
sounds like you need a new fuel pump.
Oct 02, 2009 | 1998 Honda Accord
Amber light flashing on my dell 5100, green light on motherboard
The green light just means it is plugged in and getting power.Try pulling the plug, the green light will go out. If you can remove the battery out of the motherboard, "it looks like a quarter", leaveit out for a couple minutes and out it in 'The same way it was" make sure you "look" at it before removing it, it has a little release thatenables it to lock in, or pop out. plug it in and give it a start. It may just be the settings got corrupted, that little battery saves the start settings, once it starts, we can go into the bios if any settings need changing, I'll keep an eye on this post, good luck
Mar 16, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
HP Compaq nx5000 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
