Question about Canon imageRUNNER 1023iF Black and White Copier
How to change papersize in ir 2016 canon .put it on A4 paper size
    Sniper:
  • 51 Answers
Open your drawer, you can see blue colored lever with arrow. Point that arrow to the size you want to use on your drawer.
Posted on Sep 20, 2010
Can somebody help My canon ir 2016 is showing change paper size while all setting are correct
dear >>> every region have its default paper size, for example in the middle east we are using A4 as a default size while the majority devices that come from USA are using the letter size, as a result you have to change the paper default size to match your needs .you can simply do that by right click on your printer go to printer proprieties .
Mar 12, 2016 | Canon Office Equipment & Supplies
My Canon 2016 cuts off the top 1/2 inch of the page when printing .
Hi
Make sure the papersize dial is set for the correct papersize in the copier tray.This dial is the lever you change the papersizes to tell the machine what tipe of paper you put into the tray,the dial is normally a blue colour.On top of you document feeder there are also two sensors that the machine calculate the sizes of your paper.Make sure it is not stucked.
Good luck and thanks for the support.Let me know for any futher support.
Dec 23, 2009 | Canon Office Equipment & Supplies
I have a Canon Image runner 1023. when I print i get the message load paper A4, change reg'd size, common settings. and the error light is flashing
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Nov 17, 2009 | Canon imageRUNNER 1023N Black and White...
Drawers 1 and 2 have wrong size paper displayed - says A4 but is actually letter size
I believe these paper trasy have an adustabke feature allowing you to use different sizes of paper. There is a sensor associated with the mechanism that you adjust for papersize. This sensor needs to be adjusted to teh the correct paper size.
Atypically this sensor is attached to a thumbwheel in teh paper tray. So when you adjust the paper size in teh tray you must also turn this thumb wheel to refelct the paper size
Oct 03, 2009 | Canon imageRUNNER 550 Printer
Canon ir 2016 digital copier
Are you living in the USA? The size A4 is the Europe size of paper to our letter size... You can try to take the paper tray out and look inside, for any paper jammed in the back of the paper tray area.
Mar 19, 2009 | Canon Office Equipment & Supplies
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Alarm light is on it says( check paper size) this is a canon mf57700
I had this problem also. I was unable to clear the paper size error. Finally I loaded the papersize that the printer was wanting (A4 in my case) and let it print. Once the print job finished it was back to working normal.
Oct 22, 2007 | Canon ImageClass MF5770 Laser Copier...
Canon imageRUNNER 1023iF Black and White Copier Logo
1,358 people viewed this question
old marine
old marine
