Question about Dishwashers
Am looking for a service manual for a G1140SCU Miele dishwasher so i can diagnose what the lights mean. we have no service man in our area.
  • 3 Answers
SOURCE: need service manual for HAIER HDT18PA countertop dishwasher
Click the link, then click the picture of the manual on the page, it will begin loading the manual.
HDT18PA Haier Table Top Dishwasher
Posted on Jun 07, 2009
  • 122 Answers
SOURCE: outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Posted on Sep 23, 2009
  • 122 Answers
SOURCE: The PC light on my Miele dishwasher has been on
The PC light is actually where the service tech connects his laptop to test your dishwasher - it should be a PC / Salt light. The light indicates that your salt container is empty
  • 70 Answers
SOURCE: miele dishwasher had F85 on the screen
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F85 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
Posted on Apr 28, 2010
  • 52 Answers
SOURCE: miele dishwasher my light for klarspuler in my mie...
It means you need to add Rinse Aid.
Posted on Aug 07, 2010
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
I have a Miele G7883 dishwasher displaying an error code of F4E. Anybody know what this means?
towilson -- Miele G 7883 operating instruction guide can be downloaded (no-cost) as PDF. Check this manual's FAQ for error "F" codes. If data link is being used, check connectivity. If you have more questions, please contact qualified service technician. -- SWT
Aug 04, 2010 | Miele Dishwashers
F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Apr 20, 2010 | Miele Premier-Plus Built-in Dishwasher
My miele g886 dishwasher intake/drain light keeps coming on. I checked the filter and the non return valve and drain pump. It all seems ok. I read somewhere that there is a drip pan under 2 bottom panels....
the inlet/drain light is a standard fault light and can mean anything without connecting the Miele dianostic software to the unit. This is only available to Miele service techs or service agents. If the light comes on in the first minute then it is probably a drain fault. Try checking the drain spigot at the sink end where the drain hose connects as these are usually the cause of most dishwasher faults.Hope this helps
Jan 16, 2010 | Miele G892SC SS Dishwasher
MIELE INTEGRATED DISHWASHER WONT TAKE IN WATER
Contact Miele at (800) 843-7231
They will walk you through entering service mode on the machine to diagnose the fault code by pressing a series of buttons. At that point they can let you know what exactly is wrong with you machine
Sep 12, 2009 | Miele Premier-Plus Built-in Dishwasher
Miele dishwasher
Jul 06, 2009 | Miele 24 in. G680 Built-in Dishwasher
Got a Miele G2220sci dishwasher unit, getting an undocumented error code of F19 with flashing lights, help! what does F19 mean?
Miele tech's say this is a "Flow Meter" problem, which could involve their service department.
Apr 06, 2008 | Dishwashers
Mieli water-intake light comming on?
I think it's regular salt, yes, but I've never bothered to fill mine.
Have you had a dishwasher previously? If not, check the tap where your washer gets its water to make sure it has proper water preasure. If the washer doesn't get enough water it will stop.
In my kitchen there is a separate little knob on the tap to control the water to the dishwasher. this has to be open. Mine has hot and cold selection, but only cold is connected so if I turn it on hot the washer gets no water
Nov 07, 2007 | Dishwashers
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
Owen Barnes
