Question about Fujitsu fi-5120C
FI-5120C won't scan
We have been scanning all morning. Now the scanner will not scan. We commence a scan from our Input Manager, and we get the error: "Communication failed. Make sure that the power is on, the cable is firmly connected, and the scanner is not used by another application. For details refer to manual for driver user's guide. (Code DS42019)." Then another message pops up: "The current scanner is not available. The most often occurs when the scanner has been unplugged or has been turned off." We have checked power and cable, no problems. Have cancelled all jobs we have tried to scan. Any advice appreciated.
  • VicPE Jun 26, 2008
    I have the same problem with a fi 5220c - it is very frustrating
  • 300 Answers
Reboot your pc
Posted on May 18, 2008
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
Fi 5120c scanner - Vertical Line left of Center
It is the GLASS. Line up your paper to see where the lines came from (check front side and back side). Open the scanner by pushing the Blue Button on the right. Look for the glasses at the bottom of the scanner at the spots making the lines. Clean it and re-scan.
Oct 11, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
5120C does not retain settings betwen scans. I tell it to skip blank pages and it does it on the 1st scan but not subsequent scans.
unfortunatly these settings are only temporary. If you go to the main settings you just may be able to set it permanitly (if i spelt that right...)
Feb 23, 2010 | Fujitsu fi-5120C
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Multi scan
it is only made and set up for a single scan at a time. i thought the same thing when i had one.
Jun 27, 2008 | Fujitsu fi-5120C
Fi 5120c will not scan sheets that have different color entries
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
May 29, 2008 | Fujitsu fi-5120C
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Oct 15, 2007 | Fujitsu fi-5120C
FI-5120c
Invalid orientation/long scan combination. Check the KScan ScanDirectionCap and ScanContinuousCap properties and set ScanDirection and ScanContinuous accordingly is for error 20080 and for 20090 means Peripheral stopped by user. Stop button was pressed.
Jul 31, 2007 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu fi-5120C Logo
1,964 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
