Question about Video Cameras
I have a old model No.NV-VX1EN (VHS) Panasonic VX1,Handycam, the LCD (Screen) has been damaged. Can anyone help me get information where to get a new or second hand LCD screen to replace my damaged one.
SOURCE: Service manual for Panasonic Handycam NV GS15
I fixed 2 cameras with same problem "Push Reset Switch"
Removed small foreign plastic object which was jamming mechanism without stripping.
In both cases a very tiny piece of one of the broken plastic 'catch' of the door was the problem.
Turn unit upside down and give it a good shake-up and it will drop off & problem solved.
Hope this helps.
Seedata
Posted on Feb 07, 2008
zohail
  • 1223 Answers
SOURCE: Panasonic lcd ribbon cable
u can order them email them the part discription they can send u one if u go to panasonic they will ask for a price of new cam
link for order or try ebay for this it iwll help
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Panasonic%20NVGS35&pg=3&path=98821,112403:98828&brand=Panasonic&model=NVGS35&part=
you first need to strip both the camcorder and the lcd door to get the actual cable out. It might just push into a terminal connector at either end or it might be soldered to the circuit board at either end. Once you find that out then you could probably get a piece of ribbon cable to replace it from an electronic parts supplier. You also have the option (if you have a decent soldering iron) to just use standard multicore cable and solder a colour-coded set to replace the ribbon. If the board uses connectors you would have to unsolder that too and then make up your own cable loom using very thin cable.
It's a delicate operation requiring patience and a BIG magnifying glass ..I had to fix the ribbon cable when I blew up my LCD monitor...the terminals are really tiny but it can be done!!
plsw rate me FIXYA if i helped
Posted on Mar 28, 2009
rulds2008
  • 3866 Answers
SOURCE: Driver software compatible with Vista
No garenttee's but I would like a Helpful rating accept a thanks for trying but here is a website that had loads of drivers www.driverguide.com Thaks for using fixya my only compensation is you good rating thanks
Posted on May 15, 2009
  • 107 Answers
SOURCE: i have panasonic handycam model no.
You need to install the drivers for your Camcorder in order to be able to connect to your PC. When you bought your Cam a CD came with it. Here are the steps to install the drivers.
1- Insert the CD and follow the screen to install the drivers. If you do not have your CD go to this link to download drivers for your camcorder
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders.75489
enter your model# and download the drivers
2- After installing the drivers, connect your camcorder to your PC and turn the Cam ON.
3- The drivers will be installed automatically
4- After it is finished, click start, then computer. You should see a drive with name of your camcorder. Double click that, Now you should see one or more folders containing your pictures. You can copy, delete, and view all the pictures or videos stored in your camcorder.
GOOD LUCK!!!!!!!!!
Posted on Jun 11, 2009
SOURCE: downloading the video from panasonic NV-GS15 to PC
I want to Downloading the video from panasonic NV-GS15 to PC
Posted on Jul 20, 2009
Lcd screen monitor
its may be LCD flex damage
http://www.ebay.com.au/itm/NEW-LCD-Flex-Cable-Repair-Parts-Panasonic-NV-MD10000-MD10000-F0081-/151132846898?pt=UK_Replacement_Parts_Digital_Camera_Parts&hash=item2330383b32
Mar 14, 2014 | Panasonic NV-MD10000 Camcorder
Panasonic HS900 VCR. Switch on and F03 fault appears.
You have a model that uses the K-Deck look that up using google for further information.
However F03 means locks when unloading. There are several causes of this: The Load motor or drive, timing, or the mode switch.
Aug 17, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Hello ,my VCR is the model NV-SD200 and the problem is when i load the tape after 10 seconds comes out.Please help me!
I think you might have a K-Deck model. You will find information on line about this.
I think it's probably one of two things. First damage to the carriage that lifts the tape in and out or damage elsewhere. It could be connected to the mode switch in both cases. As damage can cause the timing to be out. The mode switch can also cause trouble.
Feb 13, 2011 | Panasonic AG-1980 S-VHS VCR
The LP on my Panasonic NV FJ-630 VCR doesnt show a
I know of four places that deal in Panasonic parts and they are all on-line!
Number one is Grandata, 2 is Willow Vale, 3 is CPC.
The fourth one I have just checked on and they have the upper cylinder unit in stock at £47.99 plus P&P!
And they are Curry's Partmaster.
You might want to try the others just in case they do it cheaper, but I find that Panasonic heads tend to be all around that sort of price.
May 08, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Cannot setup to get all digital channels. Instructions no help
Try selecting factory default, this might clear any old information stored on the vcr. You should then be able to rescan and get them all.
Sep 14, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I m having panasonic nv-gs47 handycam, looking for the drivers-
Good day Sir, here's the link below that contains drivers for your panasonic
handycam. hope it will help you.
drivers
Jan 24, 2009 | Panasonic NV-GS47 Camcorder
Unable to set up clock om my vhs panasonic, please help
You have to set the time and date on the remote controle, then send it by IR to the unit !
I dont have the exacte way to follow here, but you have an idee to to it !
Dec 21, 2008 | Panasonic NV-HS1000 S-VHS VCR
Video Cameras Logo
112 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
