Question about Maxon MCB-40 40-Channels Handheld CB Radio
I have a MCB-10A and the squelch button does not turn, it is frozen.
3 Suggested Answers
  • 40 Answers
SOURCE: maxon mcb-30
check to see if the pin on the antenna is broken off. take the antenna off and look inside the bottom that goes to the radio and check to see if the pin is still there if not it is probably broken off inside the antenna jack. also check to see if the squech knob is not turned all the way to the right. if so turnit back to the left all the way. you should hear sounds.
Posted on Mar 13, 2009
  • 1274 Answers
SOURCE: my maxon cb radio model
Hi, my name is John. Try to press or flip the button or EMG. That should do the trick.enjoy....hope this was very helpful....
Posted on Sep 01, 2010
How do I adjust squelch. Squelch is locked on
I suspect you have it in the continuous monitor mode so follow the directions for getting back into the automatic squelch mode.
AUTOMATIC SQUELCH: The FRS is equipped with an automatic squelch circuitry filtering out weak transmission and unwanted noise, usually caused by terrain conditions.
MONITOR:
- This feature turns off the automatic squelch feature, either momentarily or continuously. It helps in receiving signals to its maximum range, but may pick up static signals, too.
Momentary monitor:
- Press the MON button; the monitor symbol will appear.
- Release the button to restore the automatic squelch.
Continuous monitor:
- Press the MON button for more than 2 seconds until a beep sound is heard. The monitor symbol will appear.
- To restore the automatic squelch, press and release the MON button again.
NOTE: You cannot transmit when the Monitor feature is activated.
This comes from the manual I found on-line at:
http://www.michaelknows.com/electronics/walkie-talkie-manual/
Oct 26, 2013 | BellSouth 1011 (14 Channels) 2-Way Radio
MCB-10A NEED POWER CORD
Contact Maxon either by phone or via the internet.
May 01, 2012 | Maxon HCB-10C CB Radio
My maxon cb radio model MCB-10A wont change channels it stays on channel 9
Sep 01, 2010 | Maxon MCB-40 40-Channels Handheld CB Radio
Display lights up. very,very low audio.no squelch tx light lights up when keyed. no tx
Sounds like the voltage regulator is failing. Ship it in to me for service at Dodgem250.com
Oct 12, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Can't Change Channels
you can try and ring 01388 778368 ask for steve and he may be able to help.
May 18, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Cobra PR4750WX - how do I adjust squelch?
You are right there is no adjustment. You can however turn the squelch off and this maybe what is happening to you.
To turn the squelch off you press and hold the button that is just below the push-to-talk button for at least 5 seconds.
To turn the squelch back on, you either press (less than 5 sec.) and the same button or change channels.
When talking with a specific party or group, you should use the tone coded squelch (CTCSS) and that will mitigate the noise if you are not already doing that.
Apr 18, 2009 | Cobra 22 CHANNEL 2-WAY RADIOS
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Maxon mcb-30
Jan 05, 2009 | Radio Communications
Squelch when keying ptt
I would check my ptt wiring making sure the button is set so that when you push it it switches you from RX to TX. If you have a wiring diagram that would be helpful if not are you able to get one? In any event make sure the wires are not misconnected.
Sep 12, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
No sound- audio IC amp ok, squelch circuit or squematic needed- thank you
Well my friend I have same problem with some radio. Maybe you should try just to connect detector to audio amplifier and than make an squelch circuit in AF?
Jan 27, 2007 | Maxon MCB-30 40-Channels Base CB Radio
Radio Communications Logo
32 people viewed this question
Top Maxon Radio Communications Experts
Steve
Van Allen II
Van Allen II
tvopft
Level 1 Expert
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
