Question about LG Vu CU920 Cellular Phone
How do i move multiple files from phone to memory card? Looks like I have to move photos one at a time!!!
  • 2,973 Answers
Connect the phone to the PC as a mass storage device. Use the file manager. Open the folder images or whatever you have on LG. Select as many files you want from Options->Mark. Once selected, options->Move. You would be given a chance to specify the target folder. here you can select any folder on the PC. And send all files in one go.
Similarly, when the phone is connected to the PC as a mass storage device, use My Computer and open the phone's folder that contains images. Now the procedure is the same as above. Select as many files and copy/move them and then go to the target folder and paste them there.
You can even use bluetooth to send all marked files to the PC via bluetooth. But for this you have to connect the phone to the PC through bluetooth.
Posted on Sep 17, 2010
How do you save your pics from the phone to a sims card
Use any of explorers on the phone as like you do the same on your computer.
Apr 24, 2015 | Samsung Walmart Straighttalk Net10 R355c...
I'm having this problem in my nokia e5 : My memory
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Aug 06, 2017 | Cell Phones
Download photos to pc
If you're photos are saved in your phone's internal memory, transfer them first to the memory card.
To move files from the phone to the card, perform the following steps:
1. At the main screen, tap Menu.
2. Tap My Files.
3. Tap Phone at the top of the screen.
4. Tap the desired folder.
5. Tap the desired file.
6. Tap Options.
7. Tap Move to.
8. Tap Memory card.
9. Tap the desired folder.
10. Tap Open.
11. Tap Move to.
Once you have transferred your photos to the card, the next step would be transferring those photos from the card to your computer.
To move files from the card to the computer, perform the following steps:
1. Plug one end of the USB cable into the USB port on the top of your phone.
2. Plug the other end of the USB cable into a USB port on your computer.
3. Click File Transfer on the phone.
4. If required, tap OK on the phone to exit to the main screen.
5. On the computer, in the Removable Disk dialog box, click to select Open folder to view files using Windows Explorer, and click OK.
6. Navigate to the file on your memory card that you wish to copy.
7. Right-click the file and click Copy.
8. Navigate to the desired folder on your computer.
9. Right-click and click Paste.
10. When you are finished transferring files, tap Back on the phone.
11. Tap OK to exit the card reader mode.
12. Disconnect the USB cable from your phone and from your computer.
http://www.cellphones.ca/answers/how-do-i-download-photos-from-my-phone-to-my-pc/
Nov 16, 2012 | Huawei 2x Hb5a2h 1150mah Battery For U7519...
After taking a pic fom the camera I can't find it in the photos gallery
Generally this problem cause due to the malfunction of your memory card (mass memory).When files/data are fully loaded or sometimes when the files or data were infected by virus this problem occur.So, to get rid from this issue move all the data which is stored in your phone memory,For better result remove the mass memory from the phone,move/copy all the data/files from mass memory to your pc,format the memory card,reload all the data/files to your mass memory from your pc which you have copied/moved from mass memory.Now insert the mass memory to your phone.There will be no interruption. thanks for visiting fixya
Oct 29, 2012 | Nokia N86 Smartphone
N73 show phone memory low delete some data what can i do
Hi Pooja,
Move some of your files[e.g.music files,photos,videos etc] from your phone to your memory card.This is how to:
  • Locate the file.Select on options using your left hand soft key.
  • Select move to/send to and then select on memory card.
  • Move as much files as possible to create ample phone memory.
  • When receiving files[e.g via bluetooth] select memory card as the storage destination to avoid such cases or you can go to the bluetooth applacation,select on options and then storage.Set memory card as the default bluetooth storage destination.
Hope this helps.Thanks!
Please vote this answer if helpful.
Dec 18, 2011 | Nokia N73 Cellular Phone
How can you move all/multiple pictures from phone memory to the memory card? I can only find how to move one at a time.
I suggest use USB for your phone and attached it to any PC or Laptop.. So you can move all multiple pictures from phone memory to your memory card.
Jun 19, 2011 | LG Vu CU920 Cellular Phone
How do I download my photos from my phone to my pc
send a pic txt to yur email and then rt click and save photo once you open up your email
Jun 13, 2010 | Samsung SGH-G600 Cellular Phone
How do I use a micro sd card to save photos?
Before doing the steps pls format the memory card first
To transfer pictures to memory card follow the steps below:
  1. Remove the memory card slot cover, located on the upper right side of the handset
  2. Insert a microSD memory card into the memory card slot, until it locks in place
  3. From the standby screen, press the left soft key for Menu
  4. Select My Stuff (7)
  5. Highlight Graphics, using the navigation keys
  6. Press the left soft key for Options
  7. Select Open (1)
  8. Highlight desired Photo, using the navigation keys
  9. Press the left soft key for Options
  10. Select either Move (4) or Copy (5)
  11. Select either Selected (1) or Multiple (2)
    • If Multiple, highlight each Photo, using the navigation keys
    • Press thecingular%20logo%20only.jpg key to check each Photo’s box
    • Press the left soft key for either Move or Copy
    • Highlight Memory Card, using the navigation keys
    • Press the left soft key for Select
    • Highlight the Graphics folder, using the navigation keys
    • Press the left soft key for Options
    • Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  12. Highlight Memory Card, using the navigation keys
  13. Press the left soft key for Select
  14. Highlight the Graphics folder, using the navigation keys
  15. Press the left soft key for Options
  16. Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  17. Remove the microSD memory card from the memory card slot
Oct 19, 2009 | Samsung SGH-A707 Cellular Phone
Phone memory to memory card on LG ku990
- Go to the images folder
- Select one photo (any photo)
-Go to the menu you access after pressing the book liney looking button at the bottom of the screen located next to 'view'
- In that menu, select 'Mark/Unmark' and select all the photos you want to put onto memory card.
- In the same menu as 'Mark/Unmark' is another option 'Move' which you will select after the photo selection process
- In the 'move' menu, you have two options, move to 'handset' or 'external memory' You will choose 'External memory'
- You can tell what photos are on the memory card because at the bottom of the photo menu (where the photos are like thumbnail images) is the round information i button, and next to it will appear what looks like a memory card or something of the sort icon depending on what photo is selected.
- There is a folder in the 'My Stuff' menu labeled 'External Memory'. Check there to see what things are on your memory card.
- I believe this process is same goes for music files also
Jun 03, 2009 | LG KU990 Viewty
LG Vu CU920 Cellular Phone Logo
230 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
